Floating point support in ARM926ejs
Amarnath MB
amarnath.mb at mistralsolutions.com
Fri Jan 4 10:08:12 UTC 2019
Hi,
I'm working on developing an RTEMS 5.0 BSP for a new SOC based on ARM926EJS.
I was able to successfully boot RTEMS and run hello.exe and ticker.exe
testsuite samples using u-boot.
Currently, I'm facing an issue with floating point values, in my test
Init.c file I have added a simple printf statement like below,
*float data = 1.234;printf("Data : %f\n", data);*
After loading the test executable, I'm getting the print as '*Data : %f*'
in the console. I have added
*CPU_CFLAGS = -mcpu=arm926ej-s -mthumb -mfloat-abi=soft *in the .cfg file
for the BSP.
Am I missing any further configuration here?
As per my understanding when I use -mfloat-abi=soft, then there must be a
software floating point library support in
the executable build and this library is enough for printing the float
value using %f. Please correct me if I'm wrong.
The SoC has a VFP9-S Floating point coprocessor inside, so I tried
replacing -mfloat-abi=soft with -mfloat-abi=hard.
But during the build, it gives error "configure: error: C compiler cannot
create executables".
*Thank you & Regards,*
*Amarnath MB*
URL: <http://lists.rtems.org/pipermail/users/attachments/20190104/f58c1938/attachment-0001.html>
