Floating point support in ARM926ejs
Amarnath MB
amarnath.mb at mistralsolutions.com
Fri Jan 4 10:19:49 UTC 2019
Hi,
I have made a copy of hello sample and added my testcodes to it.
I have also added '#define CONFIGURE_INIT_TASK_ATTRIBUTES
RTEMS_FLOATING_POINT'
before #include <rtems/confdefs.h>
*Thank you & Regards,*
*Amarnath MB*
On Fri, Jan 4, 2019 at 3:44 PM Sebastian Huber <
> On 04/01/2019 11:08, Amarnath MB wrote:
> > Currently, I'm facing an issue with floating point values, in my test
> > Init.c file I have added a simple printf statement like below,
> > *float data = 1.234;
> > printf("Data : %f\n", data);*
> > After loading the test executable, I'm getting the print as '*Data :
> > %f*' in the console.
> Do you use your own build system or did you modify the samples? In the
> RTEMS test suite some output function like printf() are wrapped by the
> linker to an alternative implementation without floating point support.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20190104/a37261b6/attachment.html>
