Using RTEMS chains API in non-RTEMS unit testing?
Fri Jan 4 19:28:14 UTC 2019
On Fri, Jan 4, 2019 at 12:54 AM Sebastian Huber <
> On 03/01/2019 16:39, Martin Erik Werner wrote:
> > Hello,
> > I'm currently using Google Test in order to run some unit tests on an
> > RTEMS application in a non-RTEMS Linux Development environment, via a
> > (fairly messy but operational) fake environment and mocking/faking
> > calls to RTEMS manager functionality (e.g. semaphores, message queues,
> > which are either uninteresting in the test scope, or used for
> > stimuli/checked-output).
> > I'm interested in using the RTEMS chain API, but given the current unit
> > test setup, it looks like it would then need to mock/check each
> > individual chain call and emulate its behaviour, rather than being able
> > to check only a certain result in the final chain. It would be nice to
> > avoid needing to partially re-implement the chain API behaviour in each
> > test case (or re-implement it completely in a full fake).
> > I've briefly looked at trying to separate the chain API functionality
> > in order to be able to link to it from the non-RTEMS unit test
> > application. But it appears like it is hard to avoid getting RTEMS
> > specifics pulled along with it.
> > Does anyone have previous experience with compiling parts of RTEMS like
> > this? Or any tips on potential solutions?
> It should be quite easy to satisfy the dependencies of the chain API. It
> is just RTEMS_INLINE_ROUTINE and a couple of data types.
I've copied the code out in the past and used it. There wasn't much to
address
and still shouldn't be. As Sebastian notes, the code is portable with a few
RTEMS-isms like that.
--joel
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190104/207adb2b/attachment-0002.html>
