RTEMS5 libdebugger/gdb issue
Wilkes, Jacob C. Jacob.Wilkes at jhuapl.edu
Thu Jul 11 15:38:30 UTC 2019
Hello everyone,
I am working with the current master branch of both RTEMS and RTEMS-LIBBSD on an Avnet PicoZed module (Xilinx Zynq 7015) with SMP enabled.  I am attempting to do some debugging (over Ethernet) using the remote gdb server provided by RTEMS and the arm-rtems5-gdb executable from RTEMS source builder.  I am able to connect from my host PC to the gdb server running within RTEMS on my Zynq, however I am unable to get breakpoints to work as expected.  After setting a breakpoint the system will pause but gdb on my host PC does not seem to register it (it will just remain at continue until I use ctrl-c to break out of it).
Does anyone have any idea what might be happening here?
Thanks,
   Jacob
URL: <http://lists.rtems.org/pipermail/users/attachments/20190711/52abce11/attachment.html>
