Link errors with an install using quick-start guide
groups at chichak.ca groups at chichak.ca
Mon Jul 22 06:11:37 UTC 2019
Thank you. Thank you. Thank you.
Yes, of course, once I added the configuration section and changed main into an appropriately formatted Init, it compiles nicely.
Thanks again,
Andrei
> On 2019-July-22, at 00:05, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 22/07/2019 07:58, Mr. Andrei Chichak wrote:
>> The linker is bitching about a whole bunch of missing symbols. I expect that there is a problem finding a library.
>> Any pointers?
> You need an application configuration. If you just have a main() function, then you can use the default configuration (I would always write a custom application configuration). To use the default configuration, add -lrtemsdefaultconfig to the linker command line.
