Link errors with an install using quick-start guide
Thu Jul 25 18:59:24 UTC 2019
Having a separate library for rtems default configuration breaks autoconf
probes for packages which are built using BSP specific arguments. These
have built the same way for well over a decade.
I know this can be resolved by passing in an extra library on the configure
line. But this broke a public behavior in an undesirable and subtle way.
--joel
On Mon, Jul 22, 2019 at 1:11 AM <groups at chichak.ca> wrote:
> Thank you. Thank you. Thank you.
> Yes, of course, once I added the configuration section and changed main
> into an appropriately formatted Init, it compiles nicely.
> Thanks again,
> Andrei
> > On 2019-July-22, at 00:05, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> > On 22/07/2019 07:58, Mr. Andrei Chichak wrote:
> >> The linker is bitching about a whole bunch of missing symbols. I expect
> that there is a problem finding a library.
> >> Any pointers?
> > You need an application configuration. If you just have a main()
> function, then you can use the default configuration (I would always write
> a custom application configuration). To use the default configuration, add
> -lrtemsdefaultconfig to the linker command line.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone   : +49 89 189 47 41-16
> > Fax     : +49 89 189 47 41-09
> > E-Mail  : sebastian.huber at embedded-brains.de
> > PGP     : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190725/3f2d2644/attachment.html>
