Link errors with an install using quick-start guide
Fri Jul 26 06:21:59 UTC 2019
On 26/07/2019 08:08, Chris Johns wrote:
> On 26/7/19 3:14 pm, Sebastian Huber wrote:
>>>> 1. which Autoconf stuff you need to build a multilib based configuration, and
>>> I do not follow what this means. A 3rd party library can only be built for a BSP
>>> as this is the only installed instance of an RTEMS kernel you can have.
>> I thought this is the reason why we have this stub crt0.o in Newlib?
> Ah yes, I had forgotten your efforts to move things into newlib. Thanks for
> reminding me.
>> You can build libraries without a BSP, e.g.
> Do link tests work for networking?
The network functions are not in crt0.o currently.  I am not sure what
the policy is for ctr0.o.
>> https://git.rtems.org/sebh/rtems-gtest.git/tree/rtems
>> https://github.com/siemens/embb/blob/master/scripts/build_gcc_multilibs.sh
> Nice. I look forward to your cmake doco for the User manual when we get to
> various build systems ;)
cmake is really the worst thing I have seen so far if it comes to build
systems.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
