Problem building rrtems
Nils Hölscher
nilhoel1 at gmail.com
Sun Jul 28 09:26:15 UTC 2019
Hi,
Did you take a look at the Host computer section and installed your
dependencies?
https://docs.rtems.org/branches/master/user/hosts/posix.html#xubuntu
I hope this helps.
Best,
Nils Hölscher
On Sun, 28 Jul 2019 at 07:13, utkarsh yadav <utkarshyadavin at gmail.com>
wrote:
> Hello,
> I am new to RTEMS and was trying to build it from its source code. I
> downloaded the source code of rsb and rtems from the git repository. I was
> following the steps as stated in the Quick Start section of the new user
> manual.
> On running the command ../source-builder/sb-set-builder
> --source-only-download 5/rtems-sparc
> given at this link
> <https://docs.rtems.org/branches/master/user/start/tools.html>, I got the
> following error:
> error: shell macro failed:
> /home/utkarshyadavin/quick-start/src/rsb/source-builder/sb/rtems-build-dep
> -c gcc -l lib/usr/lib/python2.7/config-x86_64-linux-gnu*
> libpython2.7*: 127: not-found
> /bin/sh: 2: libpython2.7*: not found
> Build FAILED
> Build Set: Time 0:00:27.415260
> Build FAILED
> I am building this on ubuntu 18.04 system with x86 64 bit hardware
> architecture.
> Can someone please help me resolve this issue?
> Thanks
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190728/696ad775/attachment.html>
