Problem building rrtems
Mon Jul 29 21:16:26 UTC 2019
Hi Utkarsh Yadav,
I just posted a patch to the devel at rtems.org mailing list that seems
to fix this problem. It will need to be approved by the RSB
maintainer, but you can try the fix out yourself either by getting the
patch, or applying manually the workaround. I just added the letter
'l' before the second python in source-builder/config/gdb-common-1.cfg
 line 111
Gedare
On Sat, Jul 27, 2019 at 11:13 PM utkarsh yadav <utkarshyadavin at gmail.com> wrote:
> Hello,
> I am new to RTEMS and was trying to build it from its source code. I downloaded the source code of rsb and rtems from the git repository. I was following the steps as stated in the Quick Start section of the new user manual.
> On running the command ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
> given at this link, I got the following error:
> error: shell macro failed: /home/utkarshyadavin/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc  -l lib/usr/lib/python2.7/config-x86_64-linux-gnu*
> libpython2.7*: 127: not-found
> /bin/sh: 2: libpython2.7*: not found
> Build FAILED
> Build Set: Time 0:00:27.415260
> Build FAILED
> I am building this on ubuntu 18.04 system with x86 64 bit hardware architecture.
> Can someone please help me resolve this issue?
> Thanks
> users mailing list
> users at rtems.org
