Problem building rrtems
Mon Jul 29 22:28:00 UTC 2019
On Mon, Jul 29, 2019 at 3:16 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Utkarsh Yadav,
> I just posted a patch to the devel at rtems.org mailing list that seems
> to fix this problem. It will need to be approved by the RSB
> maintainer, but you can try the fix out yourself either by getting the
> patch, or applying manually the workaround. I just added the letter
> 'l' before the second python in source-builder/config/gdb-common-1.cfg
>  line 111
I pushed the patch, please git-pull the rtems-source-builder, and try again.
> Gedare
> On Sat, Jul 27, 2019 at 11:13 PM utkarsh yadav <utkarshyadavin at gmail.com> wrote:
> > Hello,
> > I am new to RTEMS and was trying to build it from its source code. I downloaded the source code of rsb and rtems from the git repository. I was following the steps as stated in the Quick Start section of the new user manual.
> > On running the command ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
> > given at this link, I got the following error:
> > error: shell macro failed: /home/utkarshyadavin/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc  -l lib/usr/lib/python2.7/config-x86_64-linux-gnu*
> > libpython2.7*: 127: not-found
> > /bin/sh: 2: libpython2.7*: not found
> > Build FAILED
> > Build Set: Time 0:00:27.415260
> > Build FAILED
> > I am building this on ubuntu 18.04 system with x86 64 bit hardware architecture.
> > Can someone please help me resolve this issue?
> > Thanks
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
