Problem building rrtems
Michel Macena
mmacena.eng at gmail.com
Sun Jul 28 19:18:52 UTC 2019
Try to install python dev package:
> sudo apt-get install python-dev
Best,
Michel
Em dom, 28 de jul de 2019 às 06:26, Nils Hölscher <nilhoel1 at gmail.com>
escreveu:
> Hi,
> Did you take a look at the Host computer section and installed your
> dependencies?
> https://docs.rtems.org/branches/master/user/hosts/posix.html#xubuntu
> I hope this helps.
> Best,
> Nils Hölscher
> On Sun, 28 Jul 2019 at 07:13, utkarsh yadav <utkarshyadavin at gmail.com>
> wrote:
>> Hello,
>> I am new to RTEMS and was trying to build it from its source code. I
>> downloaded the source code of rsb and rtems from the git repository. I was
>> following the steps as stated in the Quick Start section of the new user
>> manual.
>> On running the command ../source-builder/sb-set-builder
>> --source-only-download 5/rtems-sparc
>> given at this link
>> <https://docs.rtems.org/branches/master/user/start/tools.html>, I got
>> the following error:
>> error: shell macro failed:
>> /home/utkarshyadavin/quick-start/src/rsb/source-builder/sb/rtems-build-dep
>> -c gcc -l lib/usr/lib/python2.7/config-x86_64-linux-gnu*
>> libpython2.7*: 127: not-found
>> /bin/sh: 2: libpython2.7*: not found
>> Build FAILED
>> Build Set: Time 0:00:27.415260
>> Build FAILED
>> I am building this on ubuntu 18.04 system with x86 64 bit hardware
>> architecture.
>> Can someone please help me resolve this issue?
>> Thanks
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190728/2f832aeb/attachment-0002.html>
