Does RTEMS POSIX open function support O_DIRECT option ?
Tue Jun 4 10:45:45 UTC 2019
On 04/06/2019 12:18, JunBeom Kim wrote:
> Dear Sir,
> I need O_DIRECT option for calling open() function for handling file I/O.
> As I check from posix-users.pdf document, there is not O_DIRECT option
> for calling open() function.
> There is supporting options from RTEMS POSIX document in below;
> -O_RDONLY, O_WRONLY, O_RDWR
> -O_APPEND, O_CREAT, O_EXCL, O_NOCTTY, O_NONBLOCK, O_TRUNC
> If O_DIRECT option is not supported by RTEMS, I should find
> alternative method.
The O_DIRECT is defined in the header file, however, not implemented in
any RTEMS file system.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
