BeagleBone Black Networking (wifi and/or wired)
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jun 7 08:34:51 UTC 2019
On 07/06/2019 10:23, Chris Johns wrote:
> Hi,
> I am looking for some information on doing either but I cannot find out what I
> need. I have run a few libbsd examples and some run and some crash. I am
> wondering if I need an device tree installed but I cannot find out which one and
> from where.
> Any hints would be most welcome.
> Thanks
> Chris
Hello Chris,
for wired network, you should be able to add libbsd and start the
network similar like for all other boards.
Wireless is still some more effort. Note that you will need the
everything buildset of libbsd for that.
If you want you can have a look at the example application that I used
during the last GSoC projects:
    https://gitlab.com/c-mauderer/rtems-bbb/tree/master/apps/wifi-sample
That application starts a wpa_supplicant. It expects a RT8188EU based
WLAN dongle. There should be a wpa_supplicant.conf on the root of your
SD card. If I remember correctly it even routes between the networks. So
you could basically use the BBB as a Ethernet to WLAN adapter.
Best regards
Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
