BeagleBone Black Networking (wifi and/or wired)
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jun 7 09:18:31 UTC 2019
On 07/06/2019 11:16, Chris Johns wrote:
> On 7/6/19 6:34 pm, Christian Mauderer wrote:
>> On 07/06/2019 10:23, Chris Johns wrote:
>>> Hi,
>>> I am looking for some information on doing either but I cannot find out what I
>>> need. I have run a few libbsd examples and some run and some crash. I am
>>> wondering if I need an device tree installed but I cannot find out which one and
>>> from where.
>>> Any hints would be most welcome.
>>> Thanks
>>> Chris
>> Hello Chris,
>> for wired network, you should be able to add libbsd and start the
>> network similar like for all other boards.
> Nice. Do I need u-boot to load an FDT? I am not currently doing that.
Yes. The libbsd drivers use the FDT.
>> Wireless is still some more effort. Note that you will need the
>> everything buildset of libbsd for that.
>> If you want you can have a look at the example application that I used
>> during the last GSoC projects:
>>     https://gitlab.com/c-mauderer/rtems-bbb/tree/master/apps/wifi-sample
>> That application starts a wpa_supplicant. It expects a RT8188EU based
>> WLAN dongle. There should be a wpa_supplicant.conf on the root of your
>> SD card. If I remember correctly it even routes between the networks. So
>> you could basically use the BBB as a Ethernet to WLAN adapter.
> Nice.
> Thanks
> Chris
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
