BeagleBone Black Networking (wifi and/or wired)
Fri Jun 7 12:38:52 UTC 2019
On 7/6/19 10:32 pm, Sebastian Huber wrote:
> On 07/06/2019 14:23, Chris Johns wrote:
>> On 7/6/19 7:41 pm, Christian Mauderer wrote:
>>> On 07/06/2019 11:19, Chris Johns wrote:
>>>> On 7/6/19 7:18 pm, Christian Mauderer wrote:
>>>> Which FDT blob do I need to load?
>>> I usually use the one from either the official Linux or the one from
>>> FreeBSD. Alternatively you can build your own from
>>>     git://xenbits.xen.org/people/ianc/device-tree-rebasing.git
>> Thanks. I have found them and I can build the default one on FreeBSD. It does
>> not build on MacOS, the `cpp` from clang does not like command line.
>> I wonder if we should include the dts source from FreeBSD in rtems-libbsp and
>> maybe some blobs. This stuff is pretty nerdy and makes libbsd awkward to use.
>> Crashing if not present is not friendly.
> For a start some documentation would be helpful too:
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#beagle
I agree, I saw this after checking there first. Once I figure out what I am
doing I will add some. I am still assembling all the pieces.
