RISC-V Support for HiFive Unleashed
Wed Jun 12 12:30:23 UTC 2019
On 11/06/2019 20:53, Molock, Dwaine S. (GSFC-5820) wrote:
> All:
> Does the current RTEMS RISC-V port support the HiFive Unleashed
> (https://www.sifive.com/boards/hifive-unleashed) development board?
If it is similar to the Qemu platform, then it should work.  The complex
drivers may be available via libbsd from FreeBSD.
> If not, what BSP should I use as a starting point to create a BSP for
> this particular board?  Is there a generic RISC-V BSP I could use?
Yes, use this BSP:
https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html#riscv
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
