stm32 external SRAM
Mr. Andrei Chichak groups at chichak.ca
Fri Jun 14 02:26:29 UTC 2019
A 407 doesn’t normally have external RAM.
ARMs have flash at 0 and the 407 has RAM at 0x2000 0000 as you discussed earlier.
If you want to work with external flash or RAM, you have to set up the FSMC or FMC to support it, but that isn’t a part of the dev board that Sebastian used for the BSP port.
The external memory is going to be very specific to your board. Which board are you working with?
A
> On 2019-June-13, at 06:23, Christian Mauderer <christian.mauderer at embedded-brains.de> wrote:
> On 05/06/2019 02:55, Jython wrote:
>> Hello!
>>     2. In the normal (non-debugging) case, the linker script still
>>        places the
>>    .text section near zero, but places the start of the .data and .bss
>>    sections at the start location of the MPC555's internal RAM. The
>>    system startup code then configures the external RAM just after the
>>    internal RAM in memory, forming one large block from the two RAM
>>    devices.
>> from https://devel.rtems.org/wiki/TBR/BSP/Ss555
>> but i dont know how to configure the external RAM just after the
>> internal RAM in memory?
>> hope you could give me some guide!
> Hello Jython,
> the documentation you linked is for an MPC. But your subject line
> mentions an STM32. What controller / BSP are you using?
> Best regards
> Christian Mauderer
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
> users mailing list
> users at rtems.org
