gdb-8.2.1 build failed on macos 10.11.6
Juan Rafael García Blanco juanrgar at gmail.com
Sat Jun 15 10:26:00 UTC 2019
Yes, I can test building gdb-8.3. However, I plan to downgrade to an older version of macOS during the next week (not because of this issue :)
Thanks,
Juan.
> On 15 Jun 2019, at 11:23, Chris Johns <chrisj at rtems.org> wrote:
> On 15/6/19 5:48 pm, Juan Rafael García Blanco wrote:
>> Here on macos 10.11.6 I have this Xcode: Version 7.3.1 (7D1014). I  cannot update if further in 10.11.6, i.e.:
>> Nebuchadnezzar:qemu juanrgar$ softwareupdate --list
>> Software Update Tool
>> Copyright 2002-2015 Apple Inc.
>> Finding available software
>> No new software available.
>> Please note that latest Xcode is not supported in all macOS versions.
> Thanks for letting us know.
> This means gdb-8.2 is broken on this version of MacOS and Xcode. I wonder if
> gdb-8.3 builds? If it does not a bug should be raised on gdb in its bug tracker.
> Would you be able to test an RSB patch to try gdb-8.3 if I create one?
> Thanks
> Chris
