stm32 external SRAM
Jython
googcheng at gmail.com
Mon Jun 17 06:32:24 UTC 2019
Thank you and the example! that is to say put extern sram init in
bsp_start( void ) function?
On Mon, Jun 17, 2019 at 1:04 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 17/06/2019 03:05, Jython wrote:
> > STM32:
> > 112KB at 2000 0000
> > 16KB at 2001 C000
> > external sram : 1MB at 0x68000000
> > does MEMORY layout support RAM2?
> Hello Jython,
> you can distribute the regions to the two RAMs. For example this BSP
> does that:
> https://git.rtems.org/rtems/tree/bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore
> Please note that you have to take a detailed look at what is used till
> your external RAM initialization run and what not. But if you put your
> external RAM initialization in an early enough step, you shouldn't get
> problems with that.
> Best regards
> Christian
> > On Fri, Jun 14, 2019 at 10:13 PM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > If you have already added the chip and it is initialized during
> startup,
> > you most likely have to add a section for it in your linker command
> > file. Depending on where your internal RAM is located and where the
> > external one is: If they are continuous that can be enough.
> > Best regards
> > Christian
> > On 14/06/2019 04:42, Jython wrote:
> > > we have added 1M ram by FSMC, and want to manage it by system
> malloc
> > > controler
> > > On Fri, Jun 14, 2019 at 10:26 AM Mr. Andrei Chichak
> > <groups at chichak.ca <mailto:groups at chichak.ca>
> > > <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>> wrote:
> > > A 407 doesn’t normally have external RAM.
> > > ARMs have flash at 0 and the 407 has RAM at 0x2000 0000 as you
> > > discussed earlier.
> > > If you want to work with external flash or RAM, you have to
> set up
> > > the FSMC or FMC to support it, but that isn’t a part of the dev
> > > board that Sebastian used for the BSP port.
> > > The external memory is going to be very specific to your board.
> > > Which board are you working with?
> > > A
> > > > On 2019-June-13, at 06:23, Christian Mauderer
> > <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> > > > On 05/06/2019 02:55, Jython wrote:
> > > >> Hello!
> > > >> 2. In the normal (non-debugging) case, the linker
> > script still
> > > >> places the
> > > >> .text section near zero, but places the start of the
> > .data and
> > > .bss
> > > >> sections at the start location of the MPC555's internal
> > RAM. The
> > > >> system startup code then configures the external RAM just
> > > after the
> > > >> internal RAM in memory, forming one large block from the
> > two RAM
> > > >> devices.
> > > >> from https://devel.rtems.org/wiki/TBR/BSP/Ss555
> > > >> but i dont know how to configure the external RAM just
> > after the
> > > >> internal RAM in memory?
> > > >> hope you could give me some guide!
> > > > Hello Jython,
> > > > the documentation you linked is for an MPC. But your subject
> > line
> > > > mentions an STM32. What controller / BSP are you using?
> > > > Best regards
> > > > Christian Mauderer
> > > > embedded brains GmbH
> > > > Herr Christian Mauderer
> > > > Dornierstr. 4
> > > > D-82178 Puchheim
> > > > Germany
> > > > email: christian.mauderer at embedded-brains.de
> > > > Phone: +49-89-18 94 741 - 18
> > > > Fax: +49-89-18 94 741 - 08
> > > > PGP: Public key available on request.
> > > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> > des EHUG.
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > > > http://lists.rtems.org/mailman/listinfo/users
> > > users mailing list
> > Dornierstr. 4
> > D-82178 Puchheim
> > Germany
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20190617/167bd30a/attachment-0001.html>
