stm32 external SRAM
Jython
googcheng at gmail.com
Tue Jun 18 05:17:30 UTC 2019
> void SRAM_fsmc_setup(void)
> unsigned char FSMC_Bank;
> int i = 0;
> // enable port clk
> RCC_AHB1ENR |= 0x0f << 3;
> RCC_AHB3ENR |= 1; // enable fsmc clock
> // af A0-A18
> stm32f4_gpio_config temp = STM32F4_PIN_FSMC(5, 0,
> STM32F4_GPIO_AF_FSMC);
> for(i = 0; i < 6; i++) //pf0-5
> temp.fields.pin_first = STM32F4_GPIO_PIN(5, i);
> temp.fields.pin_last = STM32F4_GPIO_PIN(5, i);
> stm32f4_gpio_set_config(&temp);
> // A6 PF12
> temp.fields.pin_first = STM32F4_GPIO_PIN(5, 12);
> temp.fields.pin_last = STM32F4_GPIO_PIN(5, 12);
> // A7 PF13
> temp.fields.pin_first = STM32F4_GPIO_PIN(5, 13);
> temp.fields.pin_last = STM32F4_GPIO_PIN(5, 13);
> // A8 PF14
> temp.fields.pin_first = STM32F4_GPIO_PIN(5, 14);
> temp.fields.pin_last = STM32F4_GPIO_PIN(5, 14);
> // A9 PF15
> temp.fields.pin_first = STM32F4_GPIO_PIN(5, 15);
> temp.fields.pin_last = STM32F4_GPIO_PIN(5, 15);
> // PG0-5 A10-A15
> temp.fields.pin_first = STM32F4_GPIO_PIN(6, i);
> temp.fields.pin_last = STM32F4_GPIO_PIN(6, i);
> // a16 - pd11
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 11);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 11);
> //A17
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 12);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 12);
> //A18
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 13);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 13);
> // address bus end
> // dbus setting
> // D0 PD14
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 14);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 14);
> // D1 PD15
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 15);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 15);
> // D2 PD0
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 0);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 0);
> // D3 PD1
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 1);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 1);
> // D4-12 Pe7
> for(i = 4; i < 13; i++)
> temp.fields.pin_first = STM32F4_GPIO_PIN(4, i+3);
> temp.fields.pin_last = STM32F4_GPIO_PIN(4, i+3);
> // d13 14 15 pd8
> for(i = 13; i < 16; i++)
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, i-5);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, i-5);
> //pg10 ne3
> temp.fields.pin_first = STM32F4_GPIO_PIN(6, 10);
> temp.fields.pin_last = STM32F4_GPIO_PIN(6, 10);
> //NBL pe0 pe1
> temp.fields.pin_first = STM32F4_GPIO_PIN(4, 0);
> temp.fields.pin_last = STM32F4_GPIO_PIN(4, 0);
> temp.fields.pin_first = STM32F4_GPIO_PIN(4, 1);
> temp.fields.pin_last = STM32F4_GPIO_PIN(4, 1);
> //pd4 NOE
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 4);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 4);
> //pd5 NWE
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 5);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 5);
> //pd6 NWAIT
> temp.fields.pin_first = STM32F4_GPIO_PIN(3, 6);
> temp.fields.pin_last = STM32F4_GPIO_PIN(3, 6);
> //The SRAM is connected to the second FSMC BANK (NE2)
> FSMC_Bank = 1;
> STM32_FSMC_BCR3 |= 1<<12;
> STM32_FSMC_BCR3 |= 1<<4; //16bit
> STM32_FSMC_BTR3 |= 1<<8; // Data-phase duration DATAST
> //STM32_FSMC_BTR3 |= ~(uint32_t)(1<<4);
> //STM32_FSMC_BTR3 &= ~(uint32_t)1;
> STM32_FSMC_BTR3 &= 0xffffff00;
> STM32_FSMC_BWTR3 = 0x0FFFFFFF;
> STM32_FSMC_BCR3 |= 1; //memory bank enable
> #if 0
> FSMC_Bank1->BTCR[FSMC_Bank+1] = (FSMC_BTR2_ADDSET_1) | (FSMC_BTR2_DATAST_0
> | FSMC_BTR2_DATAST_1);
> #endif
it is my later application code, i will try it , thanks!
On Tue, Jun 18, 2019 at 1:09 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 18/06/2019 03:25, Jython wrote:
> > my linkscmd is
> https://gist.github.com/goog/aad6dae4c418255dd6fb2b23bf2e6f08
> > void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
> > SRAM_fsmc_setup();
> > bsp_start_copy_sections();
> > bsp_start_clear_bss();
> > /* At this point we can use objects outside the .start section */
> > but now my code run disordered
> Which one?
> The SRAM_fsmc_setup()? In that case please note that you are in a very
> early initialization step. So most system services won't work and global
> variables are not initialized yet.
> Or your later application code? In that case: Did you do a memory test
> to check your RAM initialization? For example the routines from Michael
> Barr from here work well:
> http://www.esacademy.com/en/library/technical-articles-and-documents/miscellaneous/software-based-memory-testing.html
> > On Mon, Jun 17, 2019 at 2:45 PM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > If you put any sections into the external RAM that need
> initialization,
> > you have to init the RAM before the BSP copies it's sections. The
> STM32
> > BSP copies it's sections in bsp_start_hook_1(). So either put it in
> > bsp_start_hook_0 or in bsp_start_hook_1 before the copy_section
> calls.
> > Attention: You can't use much in these functions. They are in a very
> > early initialization stage. So be careful what you put there.
> > If you only want malloc to allocate memory from there, there might
> is a
> > later point where you can do that.
> > On 17/06/2019 08:32, Jython wrote:
> > > Thank you and the example! that is to say put extern sram init in
> > > bsp_start( void ) function?
> > > On Mon, Jun 17, 2019 at 1:04 PM Christian Mauderer
> > <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> > > On 17/06/2019 03:05, Jython wrote:
> > > > STM32:
> > > > 112KB at 2000 0000
> > > > 16KB at 2001 C000
> > > > external sram : 1MB at 0x68000000
> > > > does MEMORY layout support RAM2?
> > > Hello Jython,
> > > you can distribute the regions to the two RAMs. For example
> > this BSP
> > > does that:
> https://git.rtems.org/rtems/tree/bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore
> > > Please note that you have to take a detailed look at what is
> > used till
> > > your external RAM initialization run and what not. But if you
> > put your
> > > external RAM initialization in an early enough step, you
> > shouldn't get
> > > problems with that.
> > > Best regards
> > > Christian
> > > > On Fri, Jun 14, 2019 at 10:13 PM Christian Mauderer
> > <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
> > > > If you have already added the chip and it is initialized
> > > during startup,
> > > > you most likely have to add a section for it in your
> linker
> > > command
> > > > file. Depending on where your internal RAM is located and
> > > where the
> > > > external one is: If they are continuous that can be
> enough.
> > > > Best regards
> > > > Christian
> > > > On 14/06/2019 04:42, Jython wrote:
> > > > > we have added 1M ram by FSMC, and want to manage it by
> > > system malloc
> > > > > controler
> > > > > On Fri, Jun 14, 2019 at 10:26 AM Mr. Andrei Chichak
> > > > <groups at chichak.ca <mailto:groups at chichak.ca>
> > <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>
> > <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>>
> > <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>>>> wrote:
> > > > > A 407 doesn’t normally have external RAM.
> > > > > ARMs have flash at 0 and the 407 has RAM at 0x2000
> > 0000
> > > as you
> > > > > discussed earlier.
> > > > > If you want to work with external flash or RAM,
> > you have
> > > to set up
> > > > > the FSMC or FMC to support it, but that isn’t a
> > part of
> > > the dev
> > > > > board that Sebastian used for the BSP port.
> > > > > The external memory is going to be very specific
> > to your
> > > board.
> > > > > Which board are you working with?
> > > > > A
> > > > > > On 2019-June-13, at 06:23, Christian Mauderer
> > <mailto:christian.mauderer at embedded-brains.de>>>>> wrote:
> > > > > > On 05/06/2019 02:55, Jython wrote:
> > > > > >> Hello!
> > > > > >> 2. In the normal (non-debugging) case, the
> > linker
> > > > script still
> > > > > >> places the
> > > > > >> .text section near zero, but places the
> > start of the
> > > > .data and
> > > > > .bss
> > > > > >> sections at the start location of the
> MPC555's
> > > internal
> > > > RAM. The
> > > > > >> system startup code then configures the
> external
> > > RAM just
> > > > > after the
> > > > > >> internal RAM in memory, forming one large
> block
> > > from the
> > > > two RAM
> > > > > >> devices.
> > > > > >> from https://devel.rtems.org/wiki/TBR/BSP/Ss555
> > > > > >> but i dont know how to configure the external
> > RAM just
> > > > after the
> > > > > >> internal RAM in memory?
> > > > > >> hope you could give me some guide!
> > > > > > Hello Jython,
> > > > > > the documentation you linked is for an MPC. But
> your
> > > subject
> > > > line
> > > > > > mentions an STM32. What controller / BSP are you
> > using?
> > > > > > Best regards
> > > > > > Christian Mauderer
> > > > > > embedded brains GmbH
> > > > > > Herr Christian Mauderer
> > > > > > Dornierstr. 4
> > > > > > D-82178 Puchheim
> > > > > > Germany
> > > > > > email: christian.mauderer at embedded-brains.de
> > > > > > Phone: +49-89-18 94 741 - 18
> > > > > > Fax: +49-89-18 94 741 - 08
> > > > > > PGP: Public key available on request.
> > > > > > Diese Nachricht ist keine geschäftliche
> > Mitteilung im
> > > Sinne
> > > > des EHUG.
> > > > > > _______________________________________________
> > > > > > users mailing list
> > > > > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>>
> > > > > > http://lists.rtems.org/mailman/listinfo/users
> > > > > users mailing list
> > > > Dornierstr. 4
> > > > D-82178 Puchheim
> > > > Germany
> > > > Diese Nachricht ist keine geschäftliche Mitteilung im
> Sinne
> > > des EHUG.
> > > Dornierstr. 4
> > > D-82178 Puchheim
> > > Germany
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> > des EHUG.
> > Dornierstr. 4
> > D-82178 Puchheim
> > Germany
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20190618/839ad5fb/attachment-0001.html>
