Eclipse/LIDE Debug Issue
Jiri Gaisler
jiri at gaisler.se
Tue Jun 18 17:37:56 UTC 2019
On 6/18/19 1:53 PM, Richard.Glossop at L3T.com wrote:
> Hi, having an event in our code where the debugger just shows “exit with code = 0” and no other information is provided. Not possible to observe variables, see a stack trace, or even know where the code is executing. Does anyone know how to track this down with the LIDE or grmon?
When the program exits, print the history trace in grmon. Then run the program again in LIDE, and put a breakpoint some where in the trace. Then execution should stop before the program exits and you should be able to see the stack trace.
Jiri.
> ------------------------------------------- CONFIDENTIALITY NOTICE: This email and any attachments are for the sole use of the intended recipient and may contain material that is proprietary, confidential, privileged or otherwise legally protected or restricted under applicable government laws. Any review, disclosure, distributing or other use without expressed permission of the sender is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies without reading, printing, or saving..
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190618/6fcc4519/attachment.html>
