stm32f4 __wfi
Jython
googcheng at gmail.com
Thu Jun 20 14:43:28 UTC 2019
sleep function at the ending of loop, the loop did not begin intermediate
On Thursday, June 20, 2019, Christian Mauderer <list at c-mauderer.de> wrote:
> On 20/06/2019 13:25, Jython wrote:
> > do have service routine, handler can printk log, SLEEPONEXIT is 0
> So your handler is called? But it seems that the processor wakes up
> then. How does the "won't stop sleep mode" look like?
> > On Thu, Jun 20, 2019 at 5:19 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > On 20/06/2019 10:57, Jython wrote:
> > > a GPIO EXTI line,
> > > rtems idle phrase called __wfi, does it make stm32 enter standby
> mode?
> > > so key can not wake up it from sleep function
> > Please take a look at the reference manual of your chip. Most likely
> > it's "RM0090 Rev 18" but make sure that's the right part number:
> > https://www.st.com/resource/en/reference_manual/dm00031020.pdf
> > On page 127 there is a description of "Entering low-power mode":
> > "Low-power modes are entered by the MCU by executing the WFI
> (Wait
> > For Interrupt), or WFE (Wait for Event) instructions, or when the
> > SLEEPONEXIT bit in the Cortex ®-M4 with FPU System Control
> > register is set on Return from ISR."
> > There is also a description for "Exiting low-power mode". For WFI
> "any
> > peripheral interrupt acknowledged by the NVIC can wake up the
> device."
> > So your interrupt has to be set up.
> > Your code seems to enable the interrupt. But have you registered a
> > interrupt service routine? Otherwise you might get problems with an
> > unhandled interrupt on wakeup.
> > I only skimmed through the power controller chapter. But it seems
> that
> > if you have SLEEPDEEP bit set, you will enter a deeper sleep mode
> > where peripheral clocks can be disabled. In that state it's possible
> > that only special pins (like the WKUP) can wake up the processor
> > again. Please have a detailed look at that chapter to find out all
> > traps.
> > Best regards
> > Christian
> > > void keys_init()
> > > // config gpio
> > > stm32f4_gpio_set_config(&io_key1); // PA12
> > > stm32f4_gpio_set_config(&io_key2);
> > > stm32f4_gpio_set_config(&io_key3);
> > > stm32f4_gpio_set_config(&io_key4);
> > > // SYSCFGEN and exit map
> > > (*(uint32_t*)0x40023844) |= 1<<14;
> > > SYSCFG_EXTICR3 = 0;
> > > SYSCFG_EXTICR4 = 0;
> > > // EXIT INIT
> > > EXTI_IMR |= (1<<12);
> > > EXTI_RTSR |= (1<<12);
> > > EXTI_IMR |= (1<<11);
> > > EXTI_RTSR |= (1<<11);
> > > EXTI_IMR |= (1<<10);
> > > EXTI_RTSR |= (1<<10);
> > > EXTI_IMR |= (1<<9);
> > > EXTI_RTSR |= (1<<9);
> > > //NVIC_Init
> > > //NVIC it group2
> > > SCB_AIRCR = 0x05FA0000 | 0x500;
> > > // ip Interrupt priority register x
> > > //(*(volatile uint8_t*)0xE000E417) = 0xe0; //23
> > > //(*(volatile uint8_t*)0xE000E428) = 0xe0; // 40
> > > (*(volatile uint8_t*)0xE000E417) = 0x50; //23
> > > (*(volatile uint8_t*)0xE000E428) = 0x50; // 40
> > > // 23 40 Interrupt set-enable register x (NVIC_ISERx)
> > > // nvic enable interrupter number
> > > // 0xE000E100
> > > (*(volatile uint32_t*)0xE000E100) |= (1<<23);
> > > (*(volatile uint32_t *)0xE000E104) |= (1<< (40%32));
> > > On Thu, Jun 20, 2019 at 4:05 PM Christian Mauderer
> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > > On 20/06/2019 05:28, Jython wrote:
> > > > hi, it seems that exit key interrupt won't stop sleep mode,
> why?
> > > What do you mean by "exit key interrupt"? I don't know the
> > STM32F4 that
> > > well. So please give some more details.
> > > I would expect that either only specific interrupt sources can
> > wake up
> > > the processor from a deep sleep mode or that you can configure
> > which
> > > peripherals are still active. If your "exit key" is a GPIO
> > line with
> > > interrupt capability you should have a look at whether the
> > module is
> > > still active.
> > > Best regards
> > > Christian
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20190620/acf3f646/attachment.html>
