stm32f4 __wfi
Jython
googcheng at gmail.com
Fri Jun 21 09:53:14 UTC 2019
i got it , i have coded some low power applications with stm32cube last
year,
may i just want to know more about the sleep and why it does not stop by
EXTI , maybe i need to rewrite sleep function ?
On Fri, Jun 21, 2019 at 3:16 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 21/06/2019 02:58, Jython wrote:
> > handler https://gist.github.com/goog/7bf5ec55139a3ed43e36be5b2eee318b
> There are some things that I would strongly discourage in that interrupt
> handler (printk as long as it is not only a temporary debug output,
> delay, ...) but it shouldn't be the problem. I assume that you already
> checked, that you are testing for the right flag in the first if. So I
> would expect that you get your debug output if your interrupt occurs.
> > the main loop code
> > https://gist.github.com/goog/d83786e0eb2c97ad3126ded1987b5078
> Same again: Some details but nothing that I would see as a cause for
> your problem.
> > when i pressed key, printf("loop begin\n"); does not print immediately
> > so the sleep function does not break
> Note that printf is a interrupt driven print. So if you have problems
> with _some_ interrupts not waking up your device you might not get an
> output or maybe only a "l".
> I agree with the mail from "groups chichak.ca". It's a problem that is
> very chip specific and not really a RTEMS specific one. So it might
> would be a good idea to search for "STM32 not waking up" in the ST forums.
> > On Thu, Jun 20, 2019 at 10:47 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > On 20/06/2019 16:43, Jython wrote:
> > > sleep function at the ending of loop, the loop did not begin
> > intermediate
> > So just that I understand it correctly: Your have a loop in a task
> that
> > sends your processor to sleep at the end of the loop. Then you wake
> up
> > the processor via an interrupt and the interrupt handler is executed.
> > But you don't reach the loop again?
> > I think I remember some discussion where you wanted to put a sleep
> into
> > your idle loop? Maybe you have a double sleep?
> > > On Thursday, June 20, 2019, Christian Mauderer <list at c-mauderer.de
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > > On 20/06/2019 13:25, Jython wrote:
> > > > do have service routine, handler can printk log,
> > SLEEPONEXIT is 0
> > > So your handler is called? But it seems that the processor
> > wakes up
> > > then. How does the "won't stop sleep mode" look like?
> > > > On Thu, Jun 20, 2019 at 5:19 PM Christian Mauderer
> > > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > On 20/06/2019 10:57, Jython wrote:
> > > > > a GPIO EXTI line,
> > > > > rtems idle phrase called __wfi, does it make stm32
> enter
> > > standby mode?
> > > > > so key can not wake up it from sleep function
> > > > Please take a look at the reference manual of your chip.
> > Most
> > > likely
> > > > it's "RM0090 Rev 18" but make sure that's the right part
> > number:
> > > https://www.st.com/resource/en/reference_manual/dm00031020.pdf
> https://www.st.com/resource/en/reference_manual/dm00031020.pdf>
> > > > On page 127 there is a description of "Entering
> > low-power mode":
> > > > "Low-power modes are entered by the MCU by executing
> the
> > > WFI (Wait
> > > > For Interrupt), or WFE (Wait for Event)
> instructions, or
> > > when the
> > > > SLEEPONEXIT bit in the Cortex ®-M4 with FPU System
> > Control
> > > > register is set on Return from ISR."
> > > > There is also a description for "Exiting low-power
> > mode". For
> > > WFI "any
> > > > peripheral interrupt acknowledged by the NVIC can wake
> > up the
> > > device."
> > > > So your interrupt has to be set up.
> > > > Your code seems to enable the interrupt. But have you
> > registered a
> > > > interrupt service routine? Otherwise you might get
> problems
> > > with an
> > > > unhandled interrupt on wakeup.
> > > > I only skimmed through the power controller chapter. But
> it
> > > seems that
> > > > if you have SLEEPDEEP bit set, you will enter a deeper
> > sleep mode
> > > > where peripheral clocks can be disabled. In that state
> it's
> > > possible
> > > > that only special pins (like the WKUP) can wake up the
> > processor
> > > > again. Please have a detailed look at that chapter to
> > find out all
> > > > traps.
> > > > Best regards
> > > > Christian
> > > > > void keys_init()
> > > > > // config gpio
> > > > > stm32f4_gpio_set_config(&io_key1); // PA12
> > > > > stm32f4_gpio_set_config(&io_key2);
> > > > > stm32f4_gpio_set_config(&io_key3);
> > > > > stm32f4_gpio_set_config(&io_key4);
> > > > > // SYSCFGEN and exit map
> > > > > (*(uint32_t*)0x40023844) |= 1<<14;
> > > > > SYSCFG_EXTICR3 = 0;
> > > > > SYSCFG_EXTICR4 = 0;
> > > > > // EXIT INIT
> > > > > EXTI_IMR |= (1<<12);
> > > > > EXTI_RTSR |= (1<<12);
> > > > > EXTI_IMR |= (1<<11);
> > > > > EXTI_RTSR |= (1<<11);
> > > > > EXTI_IMR |= (1<<10);
> > > > > EXTI_RTSR |= (1<<10);
> > > > > EXTI_IMR |= (1<<9);
> > > > > EXTI_RTSR |= (1<<9);
> > > > > //NVIC_Init
> > > > > //NVIC it group2
> > > > > SCB_AIRCR = 0x05FA0000 | 0x500;
> > > > > // ip Interrupt priority register x
> > > > > //(*(volatile uint8_t*)0xE000E417) = 0xe0; //23
> > > > > //(*(volatile uint8_t*)0xE000E428) = 0xe0; //
> 40
> > > > > (*(volatile uint8_t*)0xE000E417) = 0x50; //23
> > > > > (*(volatile uint8_t*)0xE000E428) = 0x50; // 40
> > > > > // 23 40 Interrupt set-enable register x
> (NVIC_ISERx)
> > > > > // nvic enable interrupter number
> > > > > // 0xE000E100
> > > > > (*(volatile uint32_t*)0xE000E100) |= (1<<23);
> > > > > (*(volatile uint32_t *)0xE000E104) |= (1<<
> > (40%32));
> > > > > On Thu, Jun 20, 2019 at 4:05 PM Christian Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> > > > > On 20/06/2019 05:28, Jython wrote:
> > > > > > hi, it seems that exit key interrupt won't stop
> > sleep
> > > mode, why?
> > > > > What do you mean by "exit key interrupt"? I don't
> > know the
> > > > STM32F4 that
> > > > > well. So please give some more details.
> > > > > I would expect that either only specific interrupt
> > > sources can
> > > > wake up
> > > > > the processor from a deep sleep mode or that you
> can
> > > configure
> > > > which
> > > > > peripherals are still active. If your "exit key"
> > is a GPIO
> > > > line with
> > > > > interrupt capability you should have a look at
> > whether the
> > > > module is
> > > > > still active.
> > > > > Best regards
> > > > > Christian
> > > > > _______________________________________________
> > > > > users mailing list
> > > > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>>
> > > > > http://lists.rtems.org/mailman/listinfo/users
> > > <http://lists.rtems.org/mailman/listinfo/users>
> > users mailing list
> > users at rtems.org
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190621/5d3d9dd4/attachment-0001.html>
