RISC-V Support for HiFive Unleashed
Sachin Ghadi sachin.ghadi at sifive.com
Fri Jun 21 17:30:06 UTC 2019
On Wed, Jun 12, 2019 at 6:00 PM Sebastian Huber
> On 11/06/2019 20:53, Molock, Dwaine S. (GSFC-5820) wrote:
> > All:
> > Does the current RTEMS RISC-V port support the HiFive Unleashed
> > (https://www.sifive.com/boards/hifive-unleashed) development board?
> If it is similar to the Qemu platform, then it should work.  The complex
> drivers may be available via libbsd from FreeBSD.
> > If not, what BSP should I use as a starting point to create a BSP for
> > this particular board?  Is there a generic RISC-V BSP I could use?
> Yes, use this BSP:
> https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html#riscv
For Hifive Unleashed there is no BSP but RISCV core port is available as above .
I am in process of releasing one port for E series cores based SoC from Sifive.
> users mailing list
> users at rtems.org
Thanks and Regards,
Sachin Ghadi
