samples/hello no output on BBB
Nils Hölscher
nilhoel1 at gmail.com
Sat Jun 22 07:18:09 UTC 2019
Hi,
I configure with:
$../rtems/configure --prefix=$HOME/development/5 --target=arm-rtems5
--enable-rtemsbsp=beagleboneblack --enable-tests --enable-posix
And the test also pass.
On Fri, 21 Jun 2019 at 23:14, Lou Woods <Lou.Woods at oarcorp.com> wrote:
> Hello all,
> To make sure something isn’t horribly broken in RTEMS with regards to the
> BBB, I ran the RTEMS test suite on the BBB and it seems to work as
> expected. Out of 597 tests 572 tests passed including hello.exe. This is
> the latest RTEMS 5 build tree.
> I don’t have any experience with rtems-boot-image unfortunately so I’m not
> much help there. I used objcopy and mkimage to create an image loadable on
> U-boot via tftp.
I also tried this method but it doesn't work either.
> For what it’s worth this is the configure line I used:
> $ ../rtems/configure --target=arm-rtems5
> --prefix=/home/labtester/test/ATF/bsp-install/ --enable-networking
> --enable-posix --disable-smp --disable-multiprocessing --enable-tests
> --enable-cxx --enable-maintainer-mode
I configure with:
Best,
Nils
> Lou
> *From:* users <users-bounces at rtems.org> *On Behalf Of *Nils Hölscher
> *Sent:* Friday, June 21, 2019 4:03 AM
> *To:* users at rtems.org; chrisj at rtems.org
> *Subject:* samples/hello no output on BBB
> Hi,
> I make bootable SD-image for the BBB with Chris tool:
> $ rtems-boot-image -o sd-card.img -b u-boot-beaglebone -s 32m -k hello.exe
> u-boot/MLO u-boot/u-boot.img
> When I boot with serial connected I get the following output:
> Booting kernel from Legacy Image at 82000000 ...
> Image Name: RTEMS
> Created: 2019-06-17 8:03:14 UTC
> Image Type: ARM Linux Kernel Image (gzip compressed)
> Data Size: 48801 Bytes = 47.7 KiB
> Load Address: 80000000
> Entry Point: 80000000
> Verifying Checksum ... OK
> Uncompressing Kernel Image ... OK
> Starting kernel ...
> But the Hello world prints are missing.
> The board just restarts after a few minutes.
> Can anyone help me, please?
> I attached my config log from samples.
> Best,
> Nils
URL: <http://lists.rtems.org/pipermail/users/attachments/20190622/140fb176/attachment-0001.html>
