stm32f4 __wfi
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Jun 24 11:01:52 UTC 2019
On 24/06/2019 11:36, Jython wrote:
> now i have changed to RTC wakeup, my key press can wake up the board,
>     //rtems_stack_checker_report_usage();
>             PWR_EnterSTOPMode(1, 1);
>             init_main_osc();
>             usleep(100000);
>             printf("RCC_CFGR %02x\n", RCC_CFGR & 0xff);
> so i think sleep function can't be wake up by EXTI
Did you disable some time-specific functionality in your applications
configuration? For example a
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
> On Mon, Jun 24, 2019 at 3:44 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 24/06/2019 02:47, Jython wrote:
>     > that's to say EXTI wakes up from sleep function because interrupt
>     > handler log out
>     > but _CPU_Thread_Idle_body does not exit ?  want to know what is the
>     > sleep/idle exit condition?
>     The idle task is the task with the lowest priority. So it runs if no
>     other higher priority task (basically every task) is in the position to
>     run. In your case, your main task has been send to sleep with the
>     `sleep(10)` call. It should become active again after 10 seconds.
>     I vaguely remember that there was something about disabling some timing
>     mechanisms in your system. If you disabled the wrong parts, a sleep(10)
>     might never wake up again because it's missing it's timer that
>     determines whether 10 seconds passed. In that case you might want to
>     wait for some synchronization object instead (a signal, a mutex, some
>     event, ...) that you send from your interrupt.
>     PS: I re-added the user list on CC. I hope that is OK for you.
>     Best regards
>     Christian
>     > On Fri, Jun 21, 2019 at 7:09 PM Christian Mauderer
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >     On 21/06/2019 11:53, Jython wrote:
>     >     > i got it ,  i have coded some low power applications with
>     >     stm32cube last
>     >     > year,
>     >     > may i just want to know more about the sleep and why it does not
>     >     stop by
>     >     > EXTI , maybe i need to rewrite sleep function ?
>     >     `sleep()` just suspends your current task. So you will reach
>     (after a
>     >     task switch) the idle loop.
>     >     > On Fri, Jun 21, 2019 at 3:16 PM Christian Mauderer
>     >     > <christian.mauderer at embedded-brains.de
>     >     > <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
>     >     >     On 21/06/2019 02:58, Jython wrote:
>     >     >     > handler
>     >     https://gist.github.com/goog/7bf5ec55139a3ed43e36be5b2eee318b
>     >     >     There are some things that I would strongly discourage
>     in that
>     >     interrupt
>     >     >     handler (printk as long as it is not only a temporary debug
>     >     output,
>     >     >     delay, ...) but it shouldn't be the problem. I assume
>     that you
>     >     already
>     >     >     checked, that you are testing for the right flag in the
>     first
>     >     if. So I
>     >     >     would expect that you get your debug output if your
>     interrupt
>     >     occurs.
>     >     >     > the main loop code
>     https://gist.github.com/goog/d83786e0eb2c97ad3126ded1987b5078
>     >     >     Same again: Some details but nothing that I would see as a
>     >     cause for
>     >     >     your problem.
>     >     >     > when i pressed key, printf("loop begin\n"); does not print
>     >     immediately
>     >     >     > so the sleep function does not break
>     >     >     Note that printf is a interrupt driven print. So if you have
>     >     problems
>     >     >     with _some_ interrupts not waking up your device you
>     might not
>     >     get an
>     >     >     output or maybe only a "l".
>     >     >     I agree with the mail from "groups chichak.ca
>     <http://chichak.ca>
>     >     <http://chichak.ca> <http://chichak.ca>".
>     >     >     It's a problem that is
>     >     >     very chip specific and not really a RTEMS specific one.
>     So it
>     >     might
>     >     >     would be a good idea to search for "STM32 not waking up"
>     in the ST
>     >     >     forums.
>     >     >     > On Thu, Jun 20, 2019 at 10:47 PM Christian Mauderer
>     >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>     >     >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >     >     >     On 20/06/2019 16:43, Jython wrote:
>     >     >     >     > sleep function at the ending of loop, the loop
>     did not
>     >     begin
>     >     >     >     intermediate
>     >     >     >     So just that I understand it correctly: Your have
>     a loop
>     >     in a
>     >     >     task that
>     >     >     >     sends your processor to sleep at the end of the loop.
>     >     Then you
>     >     >     wake up
>     >     >     >     the processor via an interrupt and the interrupt
>     handler is
>     >     >     executed.
>     >     >     >     But you don't reach the loop again?
>     >     >     >     I think I remember some discussion where you
>     wanted to put a
>     >     >     sleep into
>     >     >     >     your idle loop? Maybe you have a double sleep?
>     >     >     >     > On Thursday, June 20, 2019, Christian Mauderer
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>     >     >     >     >     On 20/06/2019 13:25, Jython wrote:
>     >     >     >     >     > do have service routine,  handler can
>     printk log,
>     >     >     >     SLEEPONEXIT is 0
>     >     >     >     >     So your handler is called? But it seems that the
>     >     processor
>     >     >     >     wakes up
>     >     >     >     >     then. How does the "won't stop sleep mode"
>     look like?
>     >     >     >     >     > On Thu, Jun 20, 2019 at 5:19 PM Christian
>     Mauderer
>     >     >     >     >     <list at c-mauderer.de
>     >     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
>     >     >     >     >     >     On 20/06/2019 10:57, Jython wrote:
>     >     >     >     >     >     > a GPIO EXTI line,
>     >     >     >     >     >     > rtems idle phrase called __wfi, does
>     it make
>     >     >     stm32 enter
>     >     >     >     >     standby mode?
>     >     >     >     >     >     > so key can not wake up it from sleep
>     function
>     >     >     >     >     >     Please take a look at the reference manual
>     >     of your
>     >     >     chip.
>     >     >     >     Most
>     >     >     >     >     likely
>     >     >     >     >     >     it's "RM0090 Rev 18" but make sure
>     that's the
>     >     >     right part
>     >     >     >     number:
>       https://www.st.com/resource/en/reference_manual/dm00031020.pdf
>       <https://www.st.com/resource/en/reference_manual/dm00031020.pdf>
>     >     >     >     >     >     On page 127 there is a description of
>     "Entering
>     >     >     >     low-power mode":
>     >     >     >     >     >         "Low-power modes are entered by
>     the MCU by
>     >     >     executing the
>     >     >     >     >     WFI (Wait
>     >     >     >     >     >         For Interrupt), or WFE (Wait for
>     Event)
>     >     >     instructions, or
>     >     >     >     >     when the
>     >     >     >     >     >         SLEEPONEXIT bit in the Cortex ®-M4
>     with
>     >     FPU System
>     >     >     >     Control
>     >     >     >     >     >         register is set on Return from ISR."
>     >     >     >     >     >     There is also a description for "Exiting
>     >     low-power
>     >     >     >     mode". For
>     >     >     >     >     WFI "any
>     >     >     >     >     >     peripheral interrupt acknowledged by the
>     >     NVIC can wake
>     >     >     >     up the
>     >     >     >     >     device."
>     >     >     >     >     >     So your interrupt has to be set up.
>     >     >     >     >     >     Your code seems to enable the
>     interrupt. But
>     >     have you
>     >     >     >     registered a
>     >     >     >     >     >     interrupt service routine? Otherwise you
>     >     might get
>     >     >     problems
>     >     >     >     >     with an
>     >     >     >     >     >     unhandled interrupt on wakeup.
>     >     >     >     >     >     I only skimmed through the power
>     controller
>     >     >     chapter. But it
>     >     >     >     >     seems that
>     >     >     >     >     >     if you have SLEEPDEEP bit set, you will
>     >     enter a deeper
>     >     >     >     sleep mode
>     >     >     >     >     >     where peripheral clocks can be
>     disabled. In that
>     >     >     state it's
>     >     >     >     >     possible
>     >     >     >     >     >     that only special pins (like the WKUP) can
>     >     wake up the
>     >     >     >     processor
>     >     >     >     >     >     again. Please have a detailed look at that
>     >     chapter to
>     >     >     >     find out all
>     >     >     >     >     >     traps.
>     >     >     >     >     >     Best regards
>     >     >     >     >     >     Christian
>     >     >     >     >     >     >     void keys_init()
>     >     >     >     >     >     >         // config gpio
>      stm32f4_gpio_set_config(&io_key1);  //
>     >     PA12
>     >     >     >     >     >     >     stm32f4_gpio_set_config(&io_key2);
>      stm32f4_gpio_set_config(&io_key3);
>     >     >     >     >     >     >     stm32f4_gpio_set_config(&io_key4);
>     >     >     >     >     >     >         //  SYSCFGEN and exit map
>     >     >     >     >     >     >     (*(uint32_t*)0x40023844) |= 1<<14;
>     >     >     >     >     >     >         SYSCFG_EXTICR3 = 0;
>     >     >     >     >     >     >         SYSCFG_EXTICR4 = 0;
>     >     >     >     >     >     >         // EXIT INIT
>     >     >     >     >     >     >     EXTI_IMR |= (1<<12);
>     >     >     >     >     >     >     EXTI_RTSR |= (1<<12);
>     >     >     >     >     >     >         EXTI_IMR |= (1<<11);
>     >     >     >     >     >     >     EXTI_RTSR |= (1<<11);
>     >     >     >     >     >     >         EXTI_IMR |= (1<<10);
>     >     >     >     >     >     >     EXTI_RTSR |= (1<<10);
>     >     >     >     >     >     >         EXTI_IMR |= (1<<9);
>     >     >     >     >     >     >     EXTI_RTSR |= (1<<9);
>     >     >     >     >     >     >         //NVIC_Init
>     >     >     >     >     >     >         //NVIC it group2
>     >     >     >     >     >     >     SCB_AIRCR = 0x05FA0000 | 0x500;
>     >     >     >     >     >     >     // ip Interrupt priority register x
>     >     >     >     >     >     >     //(*(volatile uint8_t*)0xE000E417) =
>     >     0xe0;  //23
>     uint8_t*)0xE000E428) =
>     >     >     0xe0;  // 40
>     >     >     >     >     >     >         (*(volatile
>     >     >     0x50;  //23
>     >     >     0x50;  // 40
>     >     >     >     >     >     >     // 23 40 Interrupt set-enable
>     register x
>     >     >     (NVIC_ISERx)
>     >     >     >     >     >     >         // nvic enable interrupter
>     number
>     >     >     >     >     >     >         // 0xE000E100
>     uint32_t*)0xE000E100) |=
>     >     >     (1<<23);
>     >     >     >     >     >     >         (*(volatile uint32_t
>     *)0xE000E104)
>     >     |= (1<<
>     >     >     >     (40%32));
>     >     >     >     >     >     > On Thu, Jun 20, 2019 at 4:05 PM
>     Christian
>     >     Mauderer
>     >     >     >     >     >     <list at c-mauderer.de
>     >     >     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>> wrote:
>     >     >     >     >     >     >     On 20/06/2019 05:28, Jython wrote:
>     >     >     >     >     >     >     > hi, it seems that exit key
>     interrupt
>     >     won't
>     >     >     stop
>     >     >     >     sleep
>     >     >     >     >     mode, why?
>     >     >     >     >     >     >     What do you mean by "exit key
>     >     interrupt"? I
>     >     >     don't
>     >     >     >     know the
>     >     >     >     >     >     STM32F4 that
>     >     >     >     >     >     >     well. So please give some more
>     details.
>     >     >     >     >     >     >     I would expect that either only
>     specific
>     >     >     interrupt
>     >     >     >     >     sources can
>     >     >     >     >     >     wake up
>     >     >     >     >     >     >     the processor from a deep sleep mode
>     >     or that
>     >     >     you can
>     >     >     >     >     configure
>     >     >     >     >     >     which
>     >     >     >     >     >     >     peripherals are still active. If
>     your
>     >     "exit key"
>     >     >     >     is a GPIO
>     >     >     >     >     >     line with
>     >     >     >     >     >     >     interrupt capability you should
>     have a
>     >     look at
>     >     >     >     whether the
>     >     >     >     >     >     module is
>     >     >     >     >     >     >     still active.
>     >     >     >     >     >     >     Best regards
>     >     >     >     >     >     >     Christian
>     >      _______________________________________________
>     >     >     >     >     >     >     users mailing list
>     >     >     >     >     >     >     users at rtems.org
>     <mailto:users at rtems.org>
>     >     <mailto:users at rtems.org <mailto:users at rtems.org>>
>     >     <mailto:users at rtems.org <mailto:users at rtems.org>>>
>     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>
>     >     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>
>     >     >     >     >     <mailto:users at rtems.org
>     <mailto:users at rtems.org> <mailto:users at rtems.org
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>
>     >     >     >     >     >     <mailto:users at rtems.org
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>>
>     >      http://lists.rtems.org/mailman/listinfo/users
>     >     >     >     >     <http://lists.rtems.org/mailman/listinfo/users>
>     >     >     > _______________________________________________
>     >     >     > users at rtems.org <mailto:users at rtems.org>
>     >     >     > http://lists.rtems.org/mailman/listinfo/users
>     >     >     embedded brains GmbH
>     >     >     Herr Christian Mauderer
>     >     >     Dornierstr. 4
>     >     >     D-82178 Puchheim
>     >     >     Germany
>     >     >     email: christian.mauderer at embedded-brains.de
>     >     >     Phone: +49-89-18 94 741 - 18
>     >     >     Fax:   +49-89-18 94 741 - 08
>     >     >     PGP: Public key available on request.
>     >     >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>     >     des EHUG.
>     >     Dornierstr. 4
>     >     D-82178 Puchheim
>     >     Germany
>     des EHUG.
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> users mailing list
> users at rtems.org
Dornierstr. 4
D-82178 Puchheim
Germany
