RTEMS 5 Release
Mon Jun 24 12:06:13 UTC 2019
On 24/6/19 8:23 pm, Heinz Junkes wrote:
> Is it foreseeable when RTEMS5 will get a release?
I have made some progress however I need to fix the RSB. I completed the change
to get all the source tarballs for all host architectures however we have some
packages that are git repos I was not aware of so I need to explicitly add
support to export and archive them.
There are a few other things I need to sort out with the release procedure, for
example where all the version numbers are as this is the first change to the new
numbering system.
I would like to work on this but I have been busy there past few months and I do
releases as unfunded work.
