stm32f4 __wfi
Jython
googcheng at gmail.com
Tue Jun 25 00:30:45 UTC 2019
this is the configure:
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 5
#define CONFIGURE_MAXIMUM_TIMERS 3
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_STACK_CHECKER_ENABLED
#define CONFIGURE_INIT_TASK_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE * 2)
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
On Mon, Jun 24, 2019 at 7:01 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 24/06/2019 11:36, Jython wrote:
> > now i have changed to RTC wakeup, my key press can wake up the board,
> > //rtems_stack_checker_report_usage();
> > PWR_EnterSTOPMode(1, 1);
> > init_main_osc();
> > usleep(100000);
> > printf("RCC_CFGR %02x\n", RCC_CFGR & 0xff);
> > so i think sleep function can't be wake up by EXTI
> Did you disable some time-specific functionality in your applications
> configuration? For example a
> CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
> > On Mon, Jun 24, 2019 at 3:44 PM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > On 24/06/2019 02:47, Jython wrote:
> > > that's to say EXTI wakes up from sleep function because interrupt
> > > handler log out
> > > but _CPU_Thread_Idle_body does not exit ? want to know what is the
> > > sleep/idle exit condition?
> > The idle task is the task with the lowest priority. So it runs if no
> > other higher priority task (basically every task) is in the position
> to
> > run. In your case, your main task has been send to sleep with the
> > `sleep(10)` call. It should become active again after 10 seconds.
> > I vaguely remember that there was something about disabling some
> timing
> > mechanisms in your system. If you disabled the wrong parts, a
> sleep(10)
> > might never wake up again because it's missing it's timer that
> > determines whether 10 seconds passed. In that case you might want to
> > wait for some synchronization object instead (a signal, a mutex, some
> > event, ...) that you send from your interrupt.
> > PS: I re-added the user list on CC. I hope that is OK for you.
> > Best regards
> > Christian
> > > On Fri, Jun 21, 2019 at 7:09 PM Christian Mauderer
> > <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> > > On 21/06/2019 11:53, Jython wrote:
> > > > i got it , i have coded some low power applications with
> > > stm32cube last
> > > > year,
> > > > may i just want to know more about the sleep and why it does
> not
> > > stop by
> > > > EXTI , maybe i need to rewrite sleep function ?
> > > `sleep()` just suspends your current task. So you will reach
> > (after a
> > > task switch) the idle loop.
> > > > On Fri, Jun 21, 2019 at 3:16 PM Christian Mauderer
> > <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
> > > > On 21/06/2019 02:58, Jython wrote:
> > > > > handler
> > > https://gist.github.com/goog/7bf5ec55139a3ed43e36be5b2eee318b
> > > > There are some things that I would strongly discourage
> > in that
> > > interrupt
> > > > handler (printk as long as it is not only a temporary
> debug
> > > output,
> > > > delay, ...) but it shouldn't be the problem. I assume
> > that you
> > > already
> > > > checked, that you are testing for the right flag in the
> > first
> > > if. So I
> > > > would expect that you get your debug output if your
> > interrupt
> > > occurs.
> > > > > the main loop code
> > https://gist.github.com/goog/d83786e0eb2c97ad3126ded1987b5078
> > > > Same again: Some details but nothing that I would see as
> a
> > > cause for
> > > > your problem.
> > > > > when i pressed key, printf("loop begin\n"); does not
> print
> > > immediately
> > > > > so the sleep function does not break
> > > > Note that printf is a interrupt driven print. So if you
> have
> > > problems
> > > > with _some_ interrupts not waking up your device you
> > might not
> > > get an
> > > > output or maybe only a "l".
> > > > I agree with the mail from "groups chichak.ca
> > <http://chichak.ca>
> > > <http://chichak.ca> <http://chichak.ca>".
> > > > It's a problem that is
> > > > very chip specific and not really a RTEMS specific one.
> > So it
> > > might
> > > > would be a good idea to search for "STM32 not waking up"
> > in the ST
> > > > forums.
> > > > > On Thu, Jun 20, 2019 at 10:47 PM Christian Mauderer
> > > > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> > > > > On 20/06/2019 16:43, Jython wrote:
> > > > > > sleep function at the ending of loop, the loop
> > did not
> > > begin
> > > > > intermediate
> > > > > So just that I understand it correctly: Your have
> > a loop
> > > in a
> > > > task that
> > > > > sends your processor to sleep at the end of the
> loop.
> > > Then you
> > > > wake up
> > > > > the processor via an interrupt and the interrupt
> > handler is
> > > > executed.
> > > > > But you don't reach the loop again?
> > > > > I think I remember some discussion where you
> > wanted to put a
> > > > sleep into
> > > > > your idle loop? Maybe you have a double sleep?
> > > > > > On Thursday, June 20, 2019, Christian Mauderer
> > <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
> > > > > > On 20/06/2019 13:25, Jython wrote:
> > > > > > > do have service routine, handler can
> > printk log,
> > > > > SLEEPONEXIT is 0
> > > > > > So your handler is called? But it seems that
> the
> > > processor
> > > > > wakes up
> > > > > > then. How does the "won't stop sleep mode"
> > look like?
> > > > > > > On Thu, Jun 20, 2019 at 5:19 PM Christian
> > Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
> > > > > > > On 20/06/2019 10:57, Jython wrote:
> > > > > > > > a GPIO EXTI line,
> > > > > > > > rtems idle phrase called __wfi, does
> > it make
> > > > stm32 enter
> > > > > > standby mode?
> > > > > > > > so key can not wake up it from sleep
> > function
> > > > > > > Please take a look at the reference
> manual
> > > of your
> > > > chip.
> > > > > Most
> > > > > > likely
> > > > > > > it's "RM0090 Rev 18" but make sure
> > that's the
> > > > right part
> > > > > number:
> > https://www.st.com/resource/en/reference_manual/dm00031020.pdf
> > <https://www.st.com/resource/en/reference_manual/dm00031020.pdf>
> > > > > > > On page 127 there is a description of
> > "Entering
> > > > > low-power mode":
> > > > > > > "Low-power modes are entered by
> > the MCU by
> > > > executing the
> > > > > > WFI (Wait
> > > > > > > For Interrupt), or WFE (Wait for
> > Event)
> > > > instructions, or
> > > > > > when the
> > > > > > > SLEEPONEXIT bit in the Cortex ®-M4
> > with
> > > FPU System
> > > > > Control
> > > > > > > register is set on Return from
> ISR."
> > > > > > > There is also a description for
> "Exiting
> > > low-power
> > > > > mode". For
> > > > > > WFI "any
> > > > > > > peripheral interrupt acknowledged by
> the
> > > NVIC can wake
> > > > > up the
> > > > > > device."
> > > > > > > So your interrupt has to be set up.
> > > > > > > Your code seems to enable the
> > interrupt. But
> > > have you
> > > > > registered a
> > > > > > > interrupt service routine? Otherwise
> you
> > > might get
> > > > problems
> > > > > > with an
> > > > > > > unhandled interrupt on wakeup.
> > > > > > > I only skimmed through the power
> > controller
> > > > chapter. But it
> > > > > > seems that
> > > > > > > if you have SLEEPDEEP bit set, you will
> > > enter a deeper
> > > > > sleep mode
> > > > > > > where peripheral clocks can be
> > disabled. In that
> > > > state it's
> > > > > > possible
> > > > > > > that only special pins (like the WKUP)
> can
> > > wake up the
> > > > > processor
> > > > > > > again. Please have a detailed look at
> that
> > > chapter to
> > > > > find out all
> > > > > > > traps.
> > > > > > > Best regards
> > > > > > > Christian
> > > > > > > > void keys_init()
> > > > > > > > // config gpio
> > stm32f4_gpio_set_config(&io_key1); //
> > > PA12
> stm32f4_gpio_set_config(&io_key2);
> > stm32f4_gpio_set_config(&io_key3);
> stm32f4_gpio_set_config(&io_key4);
> > > > > > > > // SYSCFGEN and exit map
> > > > > > > > (*(uint32_t*)0x40023844) |=
> 1<<14;
> > > > > > > > SYSCFG_EXTICR3 = 0;
> > > > > > > > SYSCFG_EXTICR4 = 0;
> > > > > > > > // EXIT INIT
> > > > > > > > EXTI_IMR |= (1<<12);
> > > > > > > > EXTI_RTSR |= (1<<12);
> > > > > > > > EXTI_IMR |= (1<<11);
> > > > > > > > EXTI_RTSR |= (1<<11);
> > > > > > > > EXTI_IMR |= (1<<10);
> > > > > > > > EXTI_RTSR |= (1<<10);
> > > > > > > > EXTI_IMR |= (1<<9);
> > > > > > > > EXTI_RTSR |= (1<<9);
> > > > > > > > //NVIC_Init
> > > > > > > > //NVIC it group2
> > > > > > > > SCB_AIRCR = 0x05FA0000 | 0x500;
> > > > > > > > // ip Interrupt priority
> register x
> > > > > > > > //(*(volatile
> uint8_t*)0xE000E417) =
> > > 0xe0; //23
> > > > > > > > //(*(volatile
> > uint8_t*)0xE000E428) =
> > > > 0xe0; // 40
> > > > > > > > (*(volatile
> > > > 0x50; //23
> > > > > > > > (*(volatile
> > > > 0x50; // 40
> > > > > > > > // 23 40 Interrupt set-enable
> > register x
> > > > (NVIC_ISERx)
> > > > > > > > // nvic enable interrupter
> > number
> > > > > > > > // 0xE000E100
> > > > > > > > (*(volatile
> > uint32_t*)0xE000E100) |=
> > > > (1<<23);
> > > > > > > > (*(volatile uint32_t
> > *)0xE000E104)
> > > |= (1<<
> > > > > (40%32));
> > > > > > > > On Thu, Jun 20, 2019 at 4:05 PM
> > Christian
> > > Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>> wrote:
> > > > > > > > On 20/06/2019 05:28, Jython
> wrote:
> > > > > > > > > hi, it seems that exit key
> > interrupt
> > > won't
> > > > stop
> > > > > sleep
> > > > > > mode, why?
> > > > > > > > What do you mean by "exit key
> > > interrupt"? I
> > > > don't
> > > > > know the
> > > > > > > STM32F4 that
> > > > > > > > well. So please give some more
> > details.
> > > > > > > > I would expect that either only
> > specific
> > > > interrupt
> > > > > > sources can
> > > > > > > wake up
> > > > > > > > the processor from a deep sleep
> mode
> > > or that
> > > > you can
> > > > > > configure
> > > > > > > which
> > > > > > > > peripherals are still active. If
> > your
> > > "exit key"
> > > > > is a GPIO
> > > > > > > line with
> > > > > > > > interrupt capability you should
> > have a
> > > look at
> > > > > whether the
> > > > > > > module is
> > > > > > > > still active.
> > > > > > > > Best regards
> > > > > > > > Christian
> > > _______________________________________________
> > > > > > > > users mailing list
> > > > > > > > users at rtems.org
> > <mailto:users at rtems.org>
> > > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > > <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>>>
> > <mailto:users at rtems.org> <mailto:users at rtems.org
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>>
> > > http://lists.rtems.org/mailman/listinfo/users
> http://lists.rtems.org/mailman/listinfo/users>
> > > > > users mailing list
> > > > embedded brains GmbH
> > > > Herr Christian Mauderer
> > > > Dornierstr. 4
> > > > D-82178 Puchheim
> > > > Germany
> > > > email: christian.mauderer at embedded-brains.de
> > > > Phone: +49-89-18 94 741 - 18
> > > > Fax: +49-89-18 94 741 - 08
> > > > PGP: Public key available on request.
> > > > Diese Nachricht ist keine geschäftliche Mitteilung im
> Sinne
> > > des EHUG.
> > > Dornierstr. 4
> > > D-82178 Puchheim
> > > Germany
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> > des EHUG.
> > Dornierstr. 4
> > D-82178 Puchheim
> > Germany
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > users mailing list
> > users at rtems.org
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20190625/8e888117/attachment-0001.html>
