stm32 external SRAM
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jun 25 09:20:23 UTC 2019
On 25/06/2019 04:35, Jython wrote:
>     printf("data  test return %04x\n", memTestDataBus(0x68000002));
>         printf("addr bus test return %04x\n",
>     memTestAddressBus(0x68000000, 1024*1024));
> memtest all passed at application mode,
> when SRAM init function moves to bsp_start_hook_1 then not work
> Can i do init_main_osc in bsp_start_hook_1?
The function seems not to use any odd stuff so most likely yes. But make
sure that it doesn't need some initialized memory. Maybe you'll have to
take a look at it with objdump to make sure of that.
> On Tue, Jun 18, 2019 at 1:25 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 18/06/2019 07:17, Jython wrote:
>     >     void SRAM_fsmc_setup(void)
>     >     unsigned char FSMC_Bank;
>     >         int i = 0;
>     >         // enable port clk
>     >         RCC_AHB1ENR |= 0x0f << 3;
>     >         RCC_AHB3ENR |= 1;  // enable fsmc clock
>     >         // af A0-A18
>     >         stm32f4_gpio_config temp = STM32F4_PIN_FSMC(5, 0,
>     >     STM32F4_GPIO_AF_FSMC);
>     >         for(i = 0; i < 6; i++)  //pf0-5
>     >             temp.fields.pin_first = STM32F4_GPIO_PIN(5, i);
>     >             temp.fields.pin_last = STM32F4_GPIO_PIN(5, i);
>     >             stm32f4_gpio_set_config(&temp);
>     >         // A6 PF12
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(5, 12);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(5, 12);
>     >         // A7 PF13
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(5, 13);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(5, 13);
>     >         // A8 PF14
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(5, 14);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(5, 14);
>     >         // A9 PF15
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(5, 15);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(5, 15);
>     >         // PG0-5    A10-A15
>     >             temp.fields.pin_first = STM32F4_GPIO_PIN(6, i);
>     >             temp.fields.pin_last = STM32F4_GPIO_PIN(6, i);
>     >         // a16 - pd11
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 11);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 11);
>     >         //A17
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 12);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 12);
>     >         //A18
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 13);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 13);
>     >         // address bus end
>     >         // dbus setting
>     >         // D0 PD14
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 14);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 14);
>     >         // D1 PD15
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 15);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 15);
>     >         // D2 PD0
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 0);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 0);
>     >         // D3 PD1
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 1);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 1);
>     >         // D4-12  Pe7
>     >         for(i = 4; i < 13; i++)
>     >             temp.fields.pin_first = STM32F4_GPIO_PIN(4, i+3);
>     >             temp.fields.pin_last = STM32F4_GPIO_PIN(4, i+3);
>     >         // d13 14 15   pd8
>     >         for(i = 13; i < 16; i++)
>     >             temp.fields.pin_first = STM32F4_GPIO_PIN(3, i-5);
>     >             temp.fields.pin_last = STM32F4_GPIO_PIN(3, i-5);
>     >         //pg10 ne3
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(6, 10);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(6, 10);
>     >         //NBL pe0 pe1
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(4, 0);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(4, 0);
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(4, 1);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(4, 1);
>     >         //pd4 NOE
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 4);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 4);
>     >         //pd5 NWE
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 5);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 5);
>     >         //pd6 NWAIT
>     >         temp.fields.pin_first = STM32F4_GPIO_PIN(3, 6);
>     >         temp.fields.pin_last = STM32F4_GPIO_PIN(3, 6);
>     >     //The SRAM is connected to the second FSMC BANK (NE2)
>     >     FSMC_Bank = 1;
>     >         STM32_FSMC_BCR3 |= 1<<12;
>     >         STM32_FSMC_BCR3 |= 1<<4;  //16bit
>     >         STM32_FSMC_BTR3 |= 1<<8;  // Data-phase duration DATAST
>     >     //STM32_FSMC_BTR3 |= ~(uint32_t)(1<<4);
>     >     //STM32_FSMC_BTR3 &= ~(uint32_t)1;
>     >     STM32_FSMC_BTR3 &= 0xffffff00;
>     >         STM32_FSMC_BWTR3 = 0x0FFFFFFF;
>     >         STM32_FSMC_BCR3 |= 1;  //memory bank enable
>     >         #if 0
>     >     FSMC_Bank1->BTCR[FSMC_Bank+1] = (FSMC_BTR2_ADDSET_1) |
>     >     (FSMC_BTR2_DATAST_0 | FSMC_BTR2_DATAST_1);
>     >         #endif
>     >   it is my later application code, i will try it ,  thanks!
>     You noted that there is a stm32f4_gpio_set_config_array function too
>     that could be used to initialize more than one pin?
>     If you have some debugger available it would be good to check the
>     stm32f4_gpio_set_config. It enables some clocks which uses a interrupt
>     disable / enable. That should work but I'm not 100% sure.
>     Please take a look at the STM initialization code too whether someone
>     disables clocks or pins again later.
>     For your application code: You could switch back to the default linker
>     command file and add the mem test.
>     > On Tue, Jun 18, 2019 at 1:09 PM Christian Mauderer
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >     On 18/06/2019 03:25, Jython wrote:
>     >     > my linkscmd is
>     >     https://gist.github.com/goog/aad6dae4c418255dd6fb2b23bf2e6f08
>     >     >     void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
>     >     >       SRAM_fsmc_setup();
>     >     >       bsp_start_copy_sections();
>     >     >       bsp_start_clear_bss();
>     >     >       /* At this point we can use objects outside the .start
>     >     section */
>     >     > but now my code run disordered
>     >     Which one?
>     >     The SRAM_fsmc_setup()? In that case please note that you are
>     in a very
>     >     early initialization step. So most system services won't work
>     and global
>     >     variables are not initialized yet.
>     >     Or your later application code? In that case: Did you do a
>     memory test
>     >     to check your RAM initialization? For example the routines
>     from Michael
>     >     Barr from here work well:
>      http://www.esacademy.com/en/library/technical-articles-and-documents/miscellaneous/software-based-memory-testing.html
>     >     > On Mon, Jun 17, 2019 at 2:45 PM Christian Mauderer
>     >     > <christian.mauderer at embedded-brains.de
>     >     > <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
>     >     >     If you put any sections into the external RAM that need
>     >     initialization,
>     >     >     you have to init the RAM before the BSP copies it's
>     sections.
>     >     The STM32
>     >     >     BSP copies it's sections in bsp_start_hook_1(). So
>     either put
>     >     it in
>     >     >     bsp_start_hook_0 or in bsp_start_hook_1 before the
>     >     copy_section calls.
>     >     >     Attention: You can't use much in these functions. They
>     are in
>     >     a very
>     >     >     early initialization stage. So be careful what you put
>     there.
>     >     >     If you only want malloc to allocate memory from there, there
>     >     might is a
>     >     >     later point where you can do that.
>     >     >     On 17/06/2019 08:32, Jython wrote:
>     >     >     > Thank you and the example! that is to say put extern sram
>     >     init in
>     >     >     > bsp_start( void ) function?
>     >     >     > On Mon, Jun 17, 2019 at 1:04 PM Christian Mauderer
>     >     >     > <christian.mauderer at embedded-brains.de
>     >     >     > <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>>> wrote:
>     >     >     >     On 17/06/2019 03:05, Jython wrote:
>     >     >     >     > STM32:
>     >     >     >     >     112KB at 2000 0000
>     >     >     >     >     16KB at 2001 C000
>     >     >     >     > external sram : 1MB at 0x68000000
>     >     >     >     >  does MEMORY layout support RAM2?
>     >     >     >     Hello Jython,
>     >     >     >     you can distribute the regions to the two RAMs.
>     For example
>     >     >     this BSP
>     >     >     >     does that:
>        https://git.rtems.org/rtems/tree/bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore
>     >     >     >     Please note that you have to take a detailed look
>     at what is
>     >     >     used till
>     >     >     >     your external RAM initialization run and what not. But
>     >     if you
>     >     >     put your
>     >     >     >     external RAM initialization in an early enough
>     step, you
>     >     >     shouldn't get
>     >     >     >     problems with that.
>     >     >     >     Best regards
>     >     >     >     Christian
>     >     >     >     > On Fri, Jun 14, 2019 at 10:13 PM Christian Mauderer
>     >     >     >     > <christian.mauderer at embedded-brains.de
>     >     >     >     > <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>>>> wrote:
>     >     >     >     >     If you have already added the chip and it is
>     >     initialized
>     >     >     >     during startup,
>     >     >     >     >     you most likely have to add a section for it in
>     >     your linker
>     >     >     >     command
>     >     >     >     >     file. Depending on where your internal RAM is
>     >     located and
>     >     >     >     where the
>     >     >     >     >     external one is: If they are continuous that can
>     >     be enough.
>     >     >     >     >     Best regards
>     >     >     >     >     Christian
>     >     >     >     >     On 14/06/2019 04:42, Jython wrote:
>     >     >     >     >     > we have added 1M ram by FSMC,  and want to
>     >     manage it by
>     >     >     >     system malloc
>     >     >     >     >     > controler
>     >     >     >     >     > On Fri, Jun 14, 2019 at 10:26 AM Mr.
>     Andrei Chichak
>     >     >     >     >     <groups at chichak.ca
>     <mailto:groups at chichak.ca> <mailto:groups at chichak.ca
>     <mailto:groups at chichak.ca>>
>     >     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>
>     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>>
>     >     >     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>
>     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>>>
>     >     >     >     <mailto:groups at chichak.ca
>     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>>>>
>     >     >     >     >     > <mailto:groups at chichak.ca
>     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>>>>>> wrote:
>     >     >     >     >     >     A 407 doesn’t normally have external RAM.
>     >     >     >     >     >     ARMs have flash at 0 and the 407 has
>     RAM at
>     >     0x2000
>     >     >     0000
>     >     >     >     as you
>     >     >     >     >     >     discussed earlier.
>     >     >     >     >     >     If you want to work with external
>     flash or RAM,
>     >     >     you have
>     >     >     >     to set up
>     >     >     >     >     >     the FSMC or FMC to support it, but
>     that isn’t a
>     >     >     part of
>     >     >     >     the dev
>     >     >     >     >     >     board that Sebastian used for the BSP
>     port.
>     >     >     >     >     >     The external memory is going to be
>     very specific
>     >     >     to your
>     >     >     >     board.
>     >     >     >     >     >     Which board are you working with?
>     >     >     >     >     >     A
>     >     >     >     >     >     > On 2019-June-13, at 06:23, Christian
>     Mauderer
>     >     >     >     >     >     <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>>>>> wrote:
>     >     >     >     >     >     > On 05/06/2019 02:55, Jython wrote:
>     >     >     >     >     >     >> Hello!
>     >     >     >     >     >     >>     2. In the normal (non-debugging)
>     >     case, the
>     >     >     linker
>     >     >     >     >     script still
>     >     >     >     >     >     >>        places the
>     >     >     >     >     >     >>    .text section near zero, but
>     places the
>     >     >     start of the
>     >     >     >     >     .data and
>     >     >     >     >     >     .bss
>     >     >     >     >     >     >>    sections at the start location
>     of the
>     >     MPC555's
>     >     >     >     internal
>     >     >     >     >     RAM. The
>     >     >     >     >     >     >>    system startup code then configures
>     >     the external
>     >     >     >     RAM just
>     >     >     >     >     >     after the
>     >     >     >     >     >     >>    internal RAM in memory, forming one
>     >     large block
>     >     >     >     from the
>     >     >     >     >     two RAM
>     >     >     >     >     >     >>    devices.
>     >     >     >     >     >     >> from
>     >     https://devel.rtems.org/wiki/TBR/BSP/Ss555
>     >     >     >     >     >     >> but i dont know how to configure
>     the external
>     >     >     RAM just
>     >     >     >     >     after the
>     >     >     >     >     >     >> internal RAM in memory?
>     >     >     >     >     >     >> hope you could give me some guide!
>     >     >     >     >     >     > Hello Jython,
>     >     >     >     >     >     > the documentation you linked is for an
>     >     MPC. But your
>     >     >     >     subject
>     >     >     >     >     line
>     >     >     >     >     >     > mentions an STM32. What controller / BSP
>     >     are you
>     >     >     using?
>     >     >     >     >     >     > Best regards
>     >     >     >     >     >     > Christian Mauderer
>     >     >     >     >     >     > embedded brains GmbH
>     >     >     >     >     >     > Herr Christian Mauderer
>     >     >     >     >     >     > Dornierstr. 4
>     >     >     >     >     >     > D-82178 Puchheim
>     >     >     >     >     >     > Germany
>     >     >     >     >     >     > email:
>     >     >     >     >     >     > Phone: +49-89-18 94 741 - 18
>     >     >     >     >     >     > Fax:   +49-89-18 94 741 - 08
>     >     >     >     >     >     > PGP: Public key available on request.
>     >     >     >     >     >     > Diese Nachricht ist keine geschäftliche
>     >     >     Mitteilung im
>     >     >     >     Sinne
>     >     >     >     >     des EHUG.
>     >     _______________________________________________
>     >     >     >     >     >     > users mailing list
>     >     >     >     >     >     > users at rtems.org
>     <mailto:users at rtems.org> <mailto:users at rtems.org
>     <mailto:users at rtems.org>>
>     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>
>     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>
>     >     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>
>     >     >     >     >     <mailto:users at rtems.org
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>
>     http://lists.rtems.org/mailman/listinfo/users
>     >     >     >     >     > users at rtems.org <mailto:users at rtems.org>
>     >     >     >     >     > http://lists.rtems.org/mailman/listinfo/users
>     >     >     >     >     Dornierstr. 4
>     >     >     >     >     Germany
>     >     >     >     >     email: christian.mauderer at embedded-brains.de
>     Mitteilung
>     >     im Sinne
>     >     >     >     des EHUG.
>     >     >     >     Dornierstr. 4
>     >     >     >     Germany
>     >     >     >     Diese Nachricht ist keine geschäftliche Mitteilung
>     im Sinne
>     >     >     des EHUG.
>     >     >     Dornierstr. 4
>     >     >     D-82178 Puchheim
>     >     >     Germany
>     >     >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>     >     des EHUG.
>     >     Dornierstr. 4
>     >     D-82178 Puchheim
>     >     Germany
>     des EHUG.
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
