BeagleboneBlack - RTEMS/FreeBSD/USB Testing Failure.
JunBeom Kim jbkim at e-coretech.kr
Wed Jun 26 14:19:38 UTC 2019
Dear Sir,
I am testing RTEMS kernel example and rtems-libbsd USB example on Beaglebone
Black board.
When I test RTEMS kernel ticker example, there was not any problem.
But, when I test rtems-libbsd/usb, there is below error.
If anyone test USB on TI beagle board successfully, please advise me.
U-Boot 2018.01-g57f10f0441 (Apr 06 2019 - 04:45:02 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net:   cpsw, usb_ether
Hit any key to stop autoboot:  0
=>   fatload mmc 0 0x90000000 usb01.img
1148902 bytes read in 77 ms (14.2 MiB/s)
=> bootm 0x90000000
## Booting kernel from Legacy Image at 90000000 ...
   Image Name:   RTEMS
   Created:      2019-06-26  13:36:44 UTC
   Image Type:   ARM RTEMS Kernel Image (gzip compressed)
   Data Size:    1148838 Bytes = 1.1 MiB
   Load Address: 80000000
   Entry Point:  80000000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
## Transferring control to RTEMS (at address 80000000) ...
RTEMS Beagleboard: am335x-based
*** LIBBSD USB 1 TEST ***
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
R0   = 0x00000000 R8  = 0x00000000
R1   = 0x0000feed R9  = 0x00000000
R2   = 0x00000007 R10 = 0x00000000
R3   = 0x006e6573 R11 = 0x00000000
R4   = 0x00000007 R12 = 0x01010101
R5   = 0xfffffff7 SP  = 0x80353894
R6   = 0x801679f4 LR  = 0x80115c9c
R7   = 0x00000000 PC  = 0x80114bd8
CPSR = 0x00000113 VEC = 0x00000004
RTEMS version: 5.0.0
RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB no-repo, Newlib
dc6e94551f09d3a983afd571478d63a09d6f66fa)
executing thread ID: 0x08a010001
executing thread name: UI1
Best Regards,
JunBeom Kim
President / EmbedCoreTech
Phone: +82-31-396-5584
Fax: +82-504-065-5720
Mobile:+82-10-6425-5720
Email:  <mailto:jbkim at e-coretech.kr> jbkim at e-coretech.kr
Web:  <http://www.e-coretech.kr> www.e-coretech.kr
URL: <http://lists.rtems.org/pipermail/users/attachments/20190626/4522fa48/attachment.html>
