BeagleboneBlack - RTEMS/FreeBSD/USB Testing Failure.
JunBeom Kim jbkim at e-coretech.kr
Thu Jun 27 06:44:38 UTC 2019
Dear Chris,
Thank you very much for your help.
I will check this.
Best Regards,
JunBeom
-----Original Message-----
Sent: Thursday, June 27, 2019 3:31 PM
To: JunBeom Kim <jbkim at e-coretech.kr>; users at rtems.org
Subject: Re: BeagleboneBlack - RTEMS/FreeBSD/USB Testing Failure.
On 27/6/19 12:19 am, JunBeom Kim wrote:
> I am testing RTEMS kernel example and rtems-libbsd USB example on
> Beaglebone Black board.
> When I test RTEMS kernel ticker example, there was not any problem.
> But, when I test rtems-libbsd/usb, there is below error.
> If anyone test USB on TI beagle board successfully, please advise me.
I think you need to load a flat device tree blob when using libbsd.
I am using this blob at the moment ...
https://ftp.rtems.org/pub/rtems/people/chrisj/uboot/bbb/am335x-boneblack.dtb
FYI I have created a tool to create SD card images. The 5th example in the documentation here:
https://docs.rtems.org/branches/master/user/tools/boot-image.html#examples
shows how to create an image with an FDT blob ...
 rtems-boot-image -o sd-card.img -b u-boot-beaglebone -s 32m \
   -k dhcpcd01.exe -d am335x-boneblack.dtb MLO u-boot.img
