BeagleBone Black Networking (wifi and/or wired)
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Jun 7 15:43:24 UTC 2019
On Fri, Jun 7, 2019 at 6:09 PM Chris Johns <chrisj at rtems.org> wrote:
> On 7/6/19 10:32 pm, Sebastian Huber wrote:
> > On 07/06/2019 14:23, Chris Johns wrote:
> >> On 7/6/19 7:41 pm, Christian Mauderer wrote:
> >>> On 07/06/2019 11:19, Chris Johns wrote:
> >>>> On 7/6/19 7:18 pm, Christian Mauderer wrote:
> >>>> Which FDT blob do I need to load?
> >>> I usually use the one from either the official Linux or the one from
> >>> FreeBSD. Alternatively you can build your own from
> >>> git://xenbits.xen.org/people/ianc/device-tree-rebasing.git
> >> Thanks. I have found them and I can build the default one on FreeBSD.
> It does
> >> not build on MacOS, the `cpp` from clang does not like command line.
> >> I wonder if we should include the dts source from FreeBSD in
> rtems-libbsp and
> >> maybe some blobs. This stuff is pretty nerdy and makes libbsd awkward
> to use.
> >> Crashing if not present is not friendly.
> > For a start some documentation would be helpful too:
> > https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#beagle
> I agree, I saw this after checking there first. Once I figure out what I am
> doing I will add some. I am still assembling all the pieces.
> Hello Chris,
I recently wrote a blog post about running RTEMS on BBB:
https://blog.thelunatic.dev/getting-started-bbb-2/
Some of it can be a part of the documentation I think. I would like to
help with the documentation on Beagle BSP. :-)
Thanks
> Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190607/09513c6c/attachment-0002.html>
