stm32 external SRAM
Jython
googcheng at gmail.com
Fri Jun 14 02:42:47 UTC 2019
we have added 1M ram by FSMC, and want to manage it by system malloc
controler
On Fri, Jun 14, 2019 at 10:26 AM Mr. Andrei Chichak <groups at chichak.ca>
wrote:
> A 407 doesn’t normally have external RAM.
> ARMs have flash at 0 and the 407 has RAM at 0x2000 0000 as you discussed
> earlier.
> If you want to work with external flash or RAM, you have to set up the
> FSMC or FMC to support it, but that isn’t a part of the dev board that
> Sebastian used for the BSP port.
> The external memory is going to be very specific to your board. Which
> board are you working with?
> A
> > On 2019-June-13, at 06:23, Christian Mauderer <
> christian.mauderer at embedded-brains.de> wrote:
> > On 05/06/2019 02:55, Jython wrote:
> >> Hello!
> >> 2. In the normal (non-debugging) case, the linker script still
> >> places the
> >> .text section near zero, but places the start of the .data and .bss
> >> sections at the start location of the MPC555's internal RAM. The
> >> system startup code then configures the external RAM just after the
> >> internal RAM in memory, forming one large block from the two RAM
> >> devices.
> >> from https://devel.rtems.org/wiki/TBR/BSP/Ss555
> >> but i dont know how to configure the external RAM just after the
> >> internal RAM in memory?
> >> hope you could give me some guide!
> > Hello Jython,
> > the documentation you linked is for an MPC. But your subject line
> > mentions an STM32. What controller / BSP are you using?
> > Best regards
> > Christian Mauderer
> > embedded brains GmbH
> > Herr Christian Mauderer
> > Dornierstr. 4
> > D-82178 Puchheim
> > Germany
> > email: christian.mauderer at embedded-brains.de
> > Phone: +49-89-18 94 741 - 18
> > Fax: +49-89-18 94 741 - 08
> > PGP: Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20190614/d5729eec/attachment-0002.html>
