stm32 external SRAM
Jython googcheng at gmail.com
Tue Jun 18 01:25:35 UTC 2019
my linkscmd is https://gist.github.com/goog/aad6dae4c418255dd6fb2b23bf2e6f08
void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
>   SRAM_fsmc_setup();
>   bsp_start_copy_sections();
>   bsp_start_clear_bss();
>   /* At this point we can use objects outside the .start section */
but now my code run disordered
On Mon, Jun 17, 2019 at 2:45 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> If you put any sections into the external RAM that need initialization,
> you have to init the RAM before the BSP copies it's sections. The STM32
> BSP copies it's sections in bsp_start_hook_1(). So either put it in
> bsp_start_hook_0 or in bsp_start_hook_1 before the copy_section calls.
> Attention: You can't use much in these functions. They are in a very
> early initialization stage. So be careful what you put there.
> If you only want malloc to allocate memory from there, there might is a
> later point where you can do that.
> On 17/06/2019 08:32, Jython wrote:
> > Thank you and the example! that is to say put extern sram init in
> > bsp_start( void ) function?
> > On Mon, Jun 17, 2019 at 1:04 PM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> >     On 17/06/2019 03:05, Jython wrote:
> >     > STM32:
> >     >     112KB at 2000 0000
> >     >     16KB at 2001 C000
> >     > external sram : 1MB at 0x68000000
> >     >  does MEMORY layout support RAM2?
> >     Hello Jython,
> >     you can distribute the regions to the two RAMs. For example this BSP
> >     does that:
> https://git.rtems.org/rtems/tree/bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore
> >     Please note that you have to take a detailed look at what is used
> till
> >     your external RAM initialization run and what not. But if you put
> your
> >     external RAM initialization in an early enough step, you shouldn't
> get
> >     problems with that.
> >     Best regards
> >     Christian
> >     > On Fri, Jun 14, 2019 at 10:13 PM Christian Mauderer
> >     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> >     >     If you have already added the chip and it is initialized
> >     during startup,
> >     >     you most likely have to add a section for it in your linker
> >     command
> >     >     file. Depending on where your internal RAM is located and
> >     where the
> >     >     external one is: If they are continuous that can be enough.
> >     >     Best regards
> >     >     Christian
> >     >     On 14/06/2019 04:42, Jython wrote:
> >     >     > we have added 1M ram by FSMC,  and want to manage it by
> >     system malloc
> >     >     > controler
> >     >     > On Fri, Jun 14, 2019 at 10:26 AM Mr. Andrei Chichak
> >     >     <groups at chichak.ca <mailto:groups at chichak.ca>
> >     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>
> >     <mailto:groups at chichak.ca <mailto:groups at chichak.ca>>>> wrote:
> >     >     >     A 407 doesn’t normally have external RAM.
> >     >     >     ARMs have flash at 0 and the 407 has RAM at 0x2000 0000
> >     as you
> >     >     >     discussed earlier.
> >     >     >     If you want to work with external flash or RAM, you have
> >     to set up
> >     >     >     the FSMC or FMC to support it, but that isn’t a part of
> >     the dev
> >     >     >     board that Sebastian used for the BSP port.
> >     >     >     The external memory is going to be very specific to your
> >     board.
> >     >     >     Which board are you working with?
> >     >     >     A
> >     >     >     > On 2019-June-13, at 06:23, Christian Mauderer
> >     <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
> >     >     >     > On 05/06/2019 02:55, Jython wrote:
> >     >     >     >> Hello!
> >     >     >     >>     2. In the normal (non-debugging) case, the linker
> >     >     script still
> >     >     >     >>        places the
> >     >     >     >>    .text section near zero, but places the start of
> the
> >     >     .data and
> >     >     >     .bss
> >     >     >     >>    sections at the start location of the MPC555's
> >     internal
> >     >     RAM. The
> >     >     >     >>    system startup code then configures the external
> >     RAM just
> >     >     >     after the
> >     >     >     >>    internal RAM in memory, forming one large block
> >     from the
> >     >     two RAM
> >     >     >     >>    devices.
> >     >     >     >> from https://devel.rtems.org/wiki/TBR/BSP/Ss555
> >     >     >     >> but i dont know how to configure the external RAM just
> >     >     after the
> >     >     >     >> internal RAM in memory?
> >     >     >     >> hope you could give me some guide!
> >     >     >     > Hello Jython,
> >     >     >     > the documentation you linked is for an MPC. But your
> >     subject
> >     >     line
> >     >     >     > mentions an STM32. What controller / BSP are you using?
> >     >     >     > Best regards
> >     >     >     > Christian Mauderer
> >     >     >     > embedded brains GmbH
> >     >     >     > Herr Christian Mauderer
> >     >     >     > Dornierstr. 4
> >     >     >     > D-82178 Puchheim
> >     >     >     > Germany
> >     >     >     > email: christian.mauderer at embedded-brains.de
> >     >     >     > Phone: +49-89-18 94 741 - 18
> >     >     >     > Fax:   +49-89-18 94 741 - 08
> >     >     >     > PGP: Public key available on request.
> >     >     >     > Diese Nachricht ist keine geschäftliche Mitteilung im
> >     Sinne
> >     >     des EHUG.
> >     >     >     > _______________________________________________
> >     >     >     > users mailing list
> >     >     >     > users at rtems.org <mailto:users at rtems.org>
> >     <mailto:users at rtems.org <mailto:users at rtems.org>>
> >     <mailto:users at rtems.org <mailto:users at rtems.org>>>
> >     >     >     > http://lists.rtems.org/mailman/listinfo/users
> >     >     > users mailing list
> >     >     Dornierstr. 4
> >     >     D-82178 Puchheim
> >     >     Germany
> >     >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> >     des EHUG.
> >     Dornierstr. 4
> >     D-82178 Puchheim
> >     Germany
> >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20190618/58e3c9e4/attachment-0002.html>
