stm32f4 __wfi
Jython googcheng at gmail.com
Thu Jun 20 11:25:35 UTC 2019
do have service routine,  handler can printk log,  SLEEPONEXIT is 0
On Thu, Jun 20, 2019 at 5:19 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 20/06/2019 10:57, Jython wrote:
> > a GPIO EXTI line,
> > rtems idle phrase called __wfi, does it make stm32 enter standby mode?
> > so key can not wake up it from sleep function
> Please take a look at the reference manual of your chip. Most likely
> it's "RM0090 Rev 18" but make sure that's the right part number:
>     https://www.st.com/resource/en/reference_manual/dm00031020.pdf
> On page 127 there is a description of "Entering low-power mode":
>     "Low-power modes are entered by the MCU by executing the WFI (Wait
>     For Interrupt), or WFE (Wait for Event) instructions, or when the
>     SLEEPONEXIT bit in the Cortex ®-M4 with FPU System Control
>     register is set on Return from ISR."
> There is also a description for "Exiting low-power mode". For WFI "any
> peripheral interrupt acknowledged by the NVIC can wake up the device."
> So your interrupt has to be set up.
> Your code seems to enable the interrupt. But have you registered a
> interrupt service routine? Otherwise you might get problems with an
> unhandled interrupt on wakeup.
> I only skimmed through the power controller chapter. But it seems that
> if you have SLEEPDEEP bit set, you will enter a deeper sleep mode
> where peripheral clocks can be disabled. In that state it's possible
> that only special pins (like the WKUP) can wake up the processor
> again. Please have a detailed look at that chapter to find out all
> traps.
> Best regards
> Christian
> >     void keys_init()
> >         // config gpio
> >     stm32f4_gpio_set_config(&io_key1);  // PA12
> >     stm32f4_gpio_set_config(&io_key2);
> >         stm32f4_gpio_set_config(&io_key3);
> >     stm32f4_gpio_set_config(&io_key4);
> >         //  SYSCFGEN and exit map
> >     (*(uint32_t*)0x40023844) |= 1<<14;
> >         SYSCFG_EXTICR3 = 0;
> >         SYSCFG_EXTICR4 = 0;
> >         // EXIT INIT
> >     EXTI_IMR |= (1<<12);
> >     EXTI_RTSR |= (1<<12);
> >         EXTI_IMR |= (1<<11);
> >     EXTI_RTSR |= (1<<11);
> >         EXTI_IMR |= (1<<10);
> >     EXTI_RTSR |= (1<<10);
> >         EXTI_IMR |= (1<<9);
> >     EXTI_RTSR |= (1<<9);
> >         //NVIC_Init
> >         //NVIC it group2
> >     SCB_AIRCR = 0x05FA0000 | 0x500;
> >     // ip Interrupt priority register x
> >     //(*(volatile uint8_t*)0xE000E417) = 0xe0;  //23
> >         //(*(volatile uint8_t*)0xE000E428) = 0xe0;  // 40
> >         (*(volatile uint8_t*)0xE000E417) = 0x50;  //23
> >         (*(volatile uint8_t*)0xE000E428) = 0x50;  // 40
> >     // 23 40 Interrupt set-enable register x (NVIC_ISERx)
> >         // nvic enable interrupter number
> >         // 0xE000E100
> >         (*(volatile uint32_t*)0xE000E100) |= (1<<23);
> >         (*(volatile uint32_t *)0xE000E104) |= (1<< (40%32));
> > On Thu, Jun 20, 2019 at 4:05 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     On 20/06/2019 05:28, Jython wrote:
> >     > hi, it seems that exit key interrupt won't stop sleep mode, why?
> >     What do you mean by "exit key interrupt"? I don't know the STM32F4
> that
> >     well. So please give some more details.
> >     I would expect that either only specific interrupt sources can wake
> up
> >     the processor from a deep sleep mode or that you can configure which
> >     peripherals are still active. If your "exit key" is a GPIO line with
> >     interrupt capability you should have a look at whether the module is
> >     still active.
> >     Best regards
> >     Christian
> >     _______________________________________________
> >     users mailing list
> >     users at rtems.org <mailto:users at rtems.org>
> >     http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20190620/40cf9c8d/attachment-0002.html>
