stm32f4 __wfi
Jython
googcheng at gmail.com
Fri Jun 21 00:58:57 UTC 2019
handler https://gist.github.com/goog/7bf5ec55139a3ed43e36be5b2eee318b
the main loop code
https://gist.github.com/goog/d83786e0eb2c97ad3126ded1987b5078
when i pressed key, printf("loop begin\n"); does not print immediately
so the sleep function does not break
On Thu, Jun 20, 2019 at 10:47 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 20/06/2019 16:43, Jython wrote:
> > sleep function at the ending of loop, the loop did not begin intermediate
> So just that I understand it correctly: Your have a loop in a task that
> sends your processor to sleep at the end of the loop. Then you wake up
> the processor via an interrupt and the interrupt handler is executed.
> But you don't reach the loop again?
> I think I remember some discussion where you wanted to put a sleep into
> your idle loop? Maybe you have a double sleep?
> > On Thursday, June 20, 2019, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > On 20/06/2019 13:25, Jython wrote:
> > > do have service routine, handler can printk log, SLEEPONEXIT is 0
> > So your handler is called? But it seems that the processor wakes up
> > then. How does the "won't stop sleep mode" look like?
> > > On Thu, Jun 20, 2019 at 5:19 PM Christian Mauderer
> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > > On 20/06/2019 10:57, Jython wrote:
> > > > a GPIO EXTI line,
> > > > rtems idle phrase called __wfi, does it make stm32 enter
> > standby mode?
> > > > so key can not wake up it from sleep function
> > > Please take a look at the reference manual of your chip. Most
> > likely
> > > it's "RM0090 Rev 18" but make sure that's the right part
> number:
> > https://www.st.com/resource/en/reference_manual/dm00031020.pdf
> > <https://www.st.com/resource/en/reference_manual/dm00031020.pdf>
> > > On page 127 there is a description of "Entering low-power
> mode":
> > > "Low-power modes are entered by the MCU by executing the
> > WFI (Wait
> > > For Interrupt), or WFE (Wait for Event) instructions, or
> > when the
> > > SLEEPONEXIT bit in the Cortex ®-M4 with FPU System Control
> > > register is set on Return from ISR."
> > > There is also a description for "Exiting low-power mode". For
> > WFI "any
> > > peripheral interrupt acknowledged by the NVIC can wake up the
> > device."
> > > So your interrupt has to be set up.
> > > Your code seems to enable the interrupt. But have you
> registered a
> > > interrupt service routine? Otherwise you might get problems
> > with an
> > > unhandled interrupt on wakeup.
> > > I only skimmed through the power controller chapter. But it
> > seems that
> > > if you have SLEEPDEEP bit set, you will enter a deeper sleep
> mode
> > > where peripheral clocks can be disabled. In that state it's
> > possible
> > > that only special pins (like the WKUP) can wake up the
> processor
> > > again. Please have a detailed look at that chapter to find out
> all
> > > traps.
> > > Best regards
> > > Christian
> > > > void keys_init()
> > > > // config gpio
> > > > stm32f4_gpio_set_config(&io_key1); // PA12
> > > > stm32f4_gpio_set_config(&io_key2);
> > > > stm32f4_gpio_set_config(&io_key3);
> > > > stm32f4_gpio_set_config(&io_key4);
> > > > // SYSCFGEN and exit map
> > > > (*(uint32_t*)0x40023844) |= 1<<14;
> > > > SYSCFG_EXTICR3 = 0;
> > > > SYSCFG_EXTICR4 = 0;
> > > > // EXIT INIT
> > > > EXTI_IMR |= (1<<12);
> > > > EXTI_RTSR |= (1<<12);
> > > > EXTI_IMR |= (1<<11);
> > > > EXTI_RTSR |= (1<<11);
> > > > EXTI_IMR |= (1<<10);
> > > > EXTI_RTSR |= (1<<10);
> > > > EXTI_IMR |= (1<<9);
> > > > EXTI_RTSR |= (1<<9);
> > > > //NVIC_Init
> > > > //NVIC it group2
> > > > SCB_AIRCR = 0x05FA0000 | 0x500;
> > > > // ip Interrupt priority register x
> > > > //(*(volatile uint8_t*)0xE000E417) = 0xe0; //23
> > > > //(*(volatile uint8_t*)0xE000E428) = 0xe0; // 40
> > > > (*(volatile uint8_t*)0xE000E417) = 0x50; //23
> > > > (*(volatile uint8_t*)0xE000E428) = 0x50; // 40
> > > > // 23 40 Interrupt set-enable register x (NVIC_ISERx)
> > > > // nvic enable interrupter number
> > > > // 0xE000E100
> > > > (*(volatile uint32_t*)0xE000E100) |= (1<<23);
> > > > (*(volatile uint32_t *)0xE000E104) |= (1<< (40%32));
> > > > On Thu, Jun 20, 2019 at 4:05 PM Christian Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > On 20/06/2019 05:28, Jython wrote:
> > > > > hi, it seems that exit key interrupt won't stop sleep
> > mode, why?
> > > > What do you mean by "exit key interrupt"? I don't know
> the
> > > STM32F4 that
> > > > well. So please give some more details.
> > > > I would expect that either only specific interrupt
> > sources can
> > > wake up
> > > > the processor from a deep sleep mode or that you can
> > configure
> > > which
> > > > peripherals are still active. If your "exit key" is a
> GPIO
> > > line with
> > > > interrupt capability you should have a look at whether
> the
> > > module is
> > > > still active.
> > > > Best regards
> > > > Christian
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > > > http://lists.rtems.org/mailman/listinfo/users
> > <http://lists.rtems.org/mailman/listinfo/users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20190621/cfdfb278/attachment-0002.html>
