stm32f4 __wfi
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jun 25 08:53:26 UTC 2019
On 25/06/2019 02:30, Jython wrote:
> this is the configure:
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
> #define CONFIGURE_MAXIMUM_TASKS         5
> #define CONFIGURE_MAXIMUM_TIMERS        3
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_STACK_CHECKER_ENABLED
> #define CONFIGURE_INIT_TASK_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE * 2)
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
Should be OK. So it's quite odd that your sleep doesn't work. Did you
try whether any delay works? For example a `rtems_task_wake_after(1)`.
This should only delay one tick.
If that doesn't work (or only if you press your button): Do you reach
the clock tick interrupt? The stm32f4 uses the clock-armv7m.c so it
should be `Clock_isr` in clockimpl.h.
> On Mon, Jun 24, 2019 at 7:01 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 24/06/2019 11:36, Jython wrote:
>     > now i have changed to RTC wakeup, my key press can wake up the board,
>     >     //rtems_stack_checker_report_usage();
>     >             PWR_EnterSTOPMode(1, 1);
>     >             init_main_osc();
>     >             usleep(100000);
>     >             printf("RCC_CFGR %02x\n", RCC_CFGR & 0xff);
>     > so i think sleep function can't be wake up by EXTI
>     Did you disable some time-specific functionality in your applications
>     configuration? For example a
>     CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
>     > On Mon, Jun 24, 2019 at 3:44 PM Christian Mauderer
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >     On 24/06/2019 02:47, Jython wrote:
>     >     > that's to say EXTI wakes up from sleep function because
>     interrupt
>     >     > handler log out
>     >     > but _CPU_Thread_Idle_body does not exit ?  want to know what
>     is the
>     >     > sleep/idle exit condition?
>     >     The idle task is the task with the lowest priority. So it runs
>     if no
>     >     other higher priority task (basically every task) is in the
>     position to
>     >     run. In your case, your main task has been send to sleep with the
>     >     `sleep(10)` call. It should become active again after 10 seconds.
>     >     I vaguely remember that there was something about disabling
>     some timing
>     >     mechanisms in your system. If you disabled the wrong parts, a
>     sleep(10)
>     >     might never wake up again because it's missing it's timer that
>     >     determines whether 10 seconds passed. In that case you might
>     want to
>     >     wait for some synchronization object instead (a signal, a
>     mutex, some
>     >     event, ...) that you send from your interrupt.
>     >     PS: I re-added the user list on CC. I hope that is OK for you.
>     >     Best regards
>     >     Christian
>     >     > On Fri, Jun 21, 2019 at 7:09 PM Christian Mauderer
>     >     > <christian.mauderer at embedded-brains.de
>     >     > <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
>     >     >     On 21/06/2019 11:53, Jython wrote:
>     >     >     > i got it ,  i have coded some low power applications with
>     >     >     stm32cube last
>     >     >     > year,
>     >     >     > may i just want to know more about the sleep and why
>     it does not
>     >     >     stop by
>     >     >     > EXTI , maybe i need to rewrite sleep function ?
>     >     >     `sleep()` just suspends your current task. So you will reach
>     >     (after a
>     >     >     task switch) the idle loop.
>     >     >     > On Fri, Jun 21, 2019 at 3:16 PM Christian Mauderer
>     >     >     > <christian.mauderer at embedded-brains.de
>     >     >     > <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>>> wrote:
>     >     >     >     On 21/06/2019 02:58, Jython wrote:
>     >     >     >     > handler
>      https://gist.github.com/goog/7bf5ec55139a3ed43e36be5b2eee318b
>     >     >     >     There are some things that I would strongly discourage
>     >     in that
>     >     >     interrupt
>     >     >     >     handler (printk as long as it is not only a
>     temporary debug
>     >     >     output,
>     >     >     >     delay, ...) but it shouldn't be the problem. I assume
>     >     that you
>     >     >     already
>     >     >     >     checked, that you are testing for the right flag
>     in the
>     >     first
>     >     >     if. So I
>     >     >     >     would expect that you get your debug output if your
>     >     interrupt
>     >     >     occurs.
>     >     >     >     > the main loop code
>     >     https://gist.github.com/goog/d83786e0eb2c97ad3126ded1987b5078
>     >     >     >     Same again: Some details but nothing that I would
>     see as a
>     >     >     cause for
>     >     >     >     your problem.
>     >     >     >     > when i pressed key, printf("loop begin\n"); does
>     not print
>     >     >     immediately
>     >     >     >     > so the sleep function does not break
>     >     >     >     Note that printf is a interrupt driven print. So
>     if you have
>     >     >     problems
>     >     >     >     with _some_ interrupts not waking up your device you
>     >     might not
>     >     >     get an
>     >     >     >     output or maybe only a "l".
>     >     >     >     I agree with the mail from "groups chichak.ca
>     <http://chichak.ca>
>     >     <http://chichak.ca>
>     >     >     <http://chichak.ca> <http://chichak.ca>".
>     >     >     >     It's a problem that is
>     >     >     >     very chip specific and not really a RTEMS specific
>     one.
>     >     So it
>     >     >     might
>     >     >     >     would be a good idea to search for "STM32 not
>     waking up"
>     >     in the ST
>     >     >     >     forums.
>     >     >     >     > On Thu, Jun 20, 2019 at 10:47 PM Christian Mauderer
>     >     >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>     >     >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>
>     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>     >     >     >     >     On 20/06/2019 16:43, Jython wrote:
>     >     >     >     >     > sleep function at the ending of loop, the loop
>     >     did not
>     >     >     begin
>     >     >     >     >     intermediate
>     >     >     >     >     So just that I understand it correctly: Your
>     have
>     >     a loop
>     >     >     in a
>     >     >     >     task that
>     >     >     >     >     sends your processor to sleep at the end of
>     the loop.
>     >     >     Then you
>     >     >     >     wake up
>     >     >     >     >     the processor via an interrupt and the interrupt
>     >     handler is
>     >     >     >     executed.
>     >     >     >     >     But you don't reach the loop again?
>     >     >     >     >     I think I remember some discussion where you
>     >     wanted to put a
>     >     >     >     sleep into
>     >     >     >     >     your idle loop? Maybe you have a double sleep?
>     >     >     >     >     > On Thursday, June 20, 2019, Christian Mauderer
>     >     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
>     >     >     >     >     >     On 20/06/2019 13:25, Jython wrote:
>     >     >     >     >     >     > do have service routine,  handler can
>     >     printk log,
>     >     >     >     >     SLEEPONEXIT is 0
>     >     >     >     >     >     So your handler is called? But it
>     seems that the
>     >     >     processor
>     >     >     >     >     wakes up
>     >     >     >     >     >     then. How does the "won't stop sleep mode"
>     >     look like?
>     >     >     >     >     >     > On Thu, Jun 20, 2019 at 5:19 PM
>     Christian
>     >     Mauderer
>     >     >     >     >     >     <list at c-mauderer.de
>     >     >     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>> wrote:
>     >     >     >     >     >     >     On 20/06/2019 10:57, Jython wrote:
>     >     >     >     >     >     >     > a GPIO EXTI line,
>     >     >     >     >     >     >     > rtems idle phrase called
>     __wfi, does
>     >     it make
>     >     >     >     stm32 enter
>     >     >     >     >     >     standby mode?
>     >     >     >     >     >     >     > so key can not wake up it from
>     sleep
>     >     function
>     >     >     >     >     >     >     Please take a look at the
>     reference manual
>     >     >     of your
>     >     >     >     chip.
>     >     >     >     >     Most
>     >     >     >     >     >     likely
>     >     >     >     >     >     >     it's "RM0090 Rev 18" but make sure
>     >     that's the
>     >     >     >     right part
>     >     >     >     >     number:
>     >       https://www.st.com/resource/en/reference_manual/dm00031020.pdf
>     >       <https://www.st.com/resource/en/reference_manual/dm00031020.pdf>
>     >     >     >     >     >     >     On page 127 there is a
>     description of
>     >     "Entering
>     >     >     >     >     low-power mode":
>     >     >     >     >     >     >         "Low-power modes are entered by
>     >     the MCU by
>     >     >     >     executing the
>     >     >     >     >     >     WFI (Wait
>     >     >     >     >     >     >         For Interrupt), or WFE (Wait for
>     >     Event)
>     >     >     >     instructions, or
>     >     >     >     >     >     when the
>     >     >     >     >     >     >         SLEEPONEXIT bit in the
>     Cortex ®-M4
>     >     with
>     >     >     FPU System
>     >     >     >     >     Control
>     >     >     >     >     >     >         register is set on Return
>     from ISR."
>     >     >     >     >     >     >     There is also a description for
>     "Exiting
>     >     >     low-power
>     >     >     >     >     mode". For
>     >     >     >     >     >     WFI "any
>     >     >     >     >     >     >     peripheral interrupt
>     acknowledged by the
>     >     >     NVIC can wake
>     >     >     >     >     up the
>     >     >     >     >     >     device."
>     >     >     >     >     >     >     So your interrupt has to be set up.
>     >     >     >     >     >     >     Your code seems to enable the
>     >     interrupt. But
>     >     >     have you
>     >     >     >     >     registered a
>     >     >     >     >     >     >     interrupt service routine?
>     Otherwise you
>     >     >     might get
>     >     >     >     problems
>     >     >     >     >     >     with an
>     >     >     >     >     >     >     unhandled interrupt on wakeup.
>     >     >     >     >     >     >     I only skimmed through the power
>     >     controller
>     >     >     >     chapter. But it
>     >     >     >     >     >     seems that
>     >     >     >     >     >     >     if you have SLEEPDEEP bit set,
>     you will
>     >     >     enter a deeper
>     >     >     >     >     sleep mode
>     >     >     >     >     >     >     where peripheral clocks can be
>     >     disabled. In that
>     >     >     >     state it's
>     >     >     >     >     >     possible
>     >     >     >     >     >     >     that only special pins (like the
>     WKUP) can
>     >     >     wake up the
>     >     >     >     >     processor
>     >     >     >     >     >     >     again. Please have a detailed
>     look at that
>     >     >     chapter to
>     >     >     >     >     find out all
>     >     >     >     >     >     >     traps.
>     >     >     >     >     >     >     Best regards
>     >     >     >     >     >     >     Christian
>     >     >     >     >     >     >     >     void keys_init()
>     >     >     >     >     >     >     >         // config gpio
>     >      stm32f4_gpio_set_config(&io_key1);  //
>     >     >     PA12
>      stm32f4_gpio_set_config(&io_key2);
>     >      stm32f4_gpio_set_config(&io_key3);
>      stm32f4_gpio_set_config(&io_key4);
>     >     >     >     >     >     >     >         //  SYSCFGEN and exit map
>     >     >     >     >     >     >     >     (*(uint32_t*)0x40023844)
>     |= 1<<14;
>     >     >     >     >     >     >     >         SYSCFG_EXTICR3 = 0;
>     >     >     >     >     >     >     >         SYSCFG_EXTICR4 = 0;
>     >     >     >     >     >     >     >         // EXIT INIT
>     >     >     >     >     >     >     >     EXTI_IMR |= (1<<12);
>     >     >     >     >     >     >     >     EXTI_RTSR |= (1<<12);
>     >     >     >     >     >     >     >         EXTI_IMR |= (1<<11);
>     >     >     >     >     >     >     >     EXTI_RTSR |= (1<<11);
>     >     >     >     >     >     >     >         EXTI_IMR |= (1<<10);
>     >     >     >     >     >     >     >     EXTI_RTSR |= (1<<10);
>     >     >     >     >     >     >     >         EXTI_IMR |= (1<<9);
>     >     >     >     >     >     >     >     EXTI_RTSR |= (1<<9);
>     >     >     >     >     >     >     >         //NVIC_Init
>     >     >     >     >     >     >     >         //NVIC it group2
>     >     >     >     >     >     >     >     SCB_AIRCR = 0x05FA0000 |
>     0x500;
>     >     >     >     >     >     >     >     // ip Interrupt priority
>     register x
>     >     >     >     >     >     >     >     //(*(volatile
>     uint8_t*)0xE000E417) =
>     >     >     0xe0;  //23
>     >     uint8_t*)0xE000E428) =
>     >     >     >     0xe0;  // 40
>     >     >     >     >     >     >     >         (*(volatile
>     >     >     >     0x50;  //23
>     >     >     >     0x50;  // 40
>     >     >     >     >     >     >     >     // 23 40 Interrupt set-enable
>     >     register x
>     >     >     >     (NVIC_ISERx)
>     >     >     >     >     >     >     >         // nvic enable interrupter
>     >     number
>     >     >     >     >     >     >     >         // 0xE000E100
>     >     uint32_t*)0xE000E100) |=
>     >     >     >     (1<<23);
>     >     >     >     >     >     >     >         (*(volatile uint32_t
>     >     *)0xE000E104)
>     >     >     |= (1<<
>     >     >     >     >     (40%32));
>     >     >     >     >     >     >     > On Thu, Jun 20, 2019 at 4:05 PM
>     >     Christian
>     >     >     Mauderer
>     >     >     >     >     >     >     <list at c-mauderer.de
>     >     >     >     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>>> wrote:
>     >     >     >     >     >     >     >     On 20/06/2019 05:28,
>     Jython wrote:
>     >     >     >     >     >     >     >     > hi, it seems that exit key
>     >     interrupt
>     >     >     won't
>     >     >     >     stop
>     >     >     >     >     sleep
>     >     >     >     >     >     mode, why?
>     >     >     >     >     >     >     >     What do you mean by "exit key
>     >     >     interrupt"? I
>     >     >     >     don't
>     >     >     >     >     know the
>     >     >     >     >     >     >     STM32F4 that
>     >     >     >     >     >     >     >     well. So please give some more
>     >     details.
>     >     >     >     >     >     >     >     I would expect that either
>     only
>     >     specific
>     >     >     >     interrupt
>     >     >     >     >     >     sources can
>     >     >     >     >     >     >     wake up
>     >     >     >     >     >     >     >     the processor from a deep
>     sleep mode
>     >     >     or that
>     >     >     >     you can
>     >     >     >     >     >     configure
>     >     >     >     >     >     >     which
>     >     >     >     >     >     >     >     peripherals are still
>     active. If
>     >     your
>     >     >     "exit key"
>     >     >     >     >     is a GPIO
>     >     >     >     >     >     >     line with
>     >     >     >     >     >     >     >     interrupt capability you
>     should
>     >     have a
>     >     >     look at
>     >     >     >     >     whether the
>     >     >     >     >     >     >     module is
>     >     >     >     >     >     >     >     still active.
>     >     >     >     >     >     >     >     Best regards
>     >     >     >     >     >     >     >     Christian
>     >     >      _______________________________________________
>     >     >     >     >     >     >     >     users mailing list
>     >     >     >     >     >     >     >     users at rtems.org
>     <mailto:users at rtems.org>
>     >     <mailto:users at rtems.org <mailto:users at rtems.org>>
>     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>
>     >     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>
>     >     >     >     >     <mailto:users at rtems.org
>     <mailto:users at rtems.org> <mailto:users at rtems.org
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>
>     >     >     >     >     >     <mailto:users at rtems.org
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>>
>     >     >     >     >     >     >     <mailto:users at rtems.org
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>>>>
>     >     >      http://lists.rtems.org/mailman/listinfo/users
>      <http://lists.rtems.org/mailman/listinfo/users>
>     >     >     >     > _______________________________________________
>     >     >     >     > users at rtems.org <mailto:users at rtems.org>
>     >     >     >     > http://lists.rtems.org/mailman/listinfo/users
>     >     >     >     embedded brains GmbH
>     >     >     >     Herr Christian Mauderer
>     >     >     >     Dornierstr. 4
>     >     >     >     D-82178 Puchheim
>     >     >     >     Germany
>     >     >     >     email: christian.mauderer at embedded-brains.de
>     >     >     >     Phone: +49-89-18 94 741 - 18
>     >     >     >     Fax:   +49-89-18 94 741 - 08
>     >     >     >     PGP: Public key available on request.
>     >     >     >     Diese Nachricht ist keine geschäftliche Mitteilung
>     im Sinne
>     >     >     des EHUG.
>     >     >     Dornierstr. 4
>     >     >     D-82178 Puchheim
>     >     >     Germany
>     >     >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>     >     des EHUG.
>     >     Dornierstr. 4
>     >     D-82178 Puchheim
>     >     Germany
>     des EHUG.
>     > users mailing list
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
