Beaglebone help needed
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Mar 7 10:03:20 UTC 2019
Am 07.03.19 um 09:52 schrieb Sarvesh Patkar:
> Hey Chris and Christian,
> Thank you for the prompt responses.
> I think there is no update needed to the rtems-source-builder at this
> time for beaglebone. After understanding what Christian told me, I
> realized that I just needed to use the rtems-arm build set. Then, I
> followed this
> README https://git.rtems.org/rtems/tree/bsps/arm/beagle/README from the
> master branch of rtems and ran the ticker sample on the beaglebone.
> For now, I think I will stick to figuring out more about the PRU or ADC
> peripherals and try to write the respective drivers for the BSP.  Since
> I am not associated with GSoC or any other institute, I will keep an eye
> on the mailing lists and make sure I am not duplicating work which
> others are doing on the Beaglebone black.
> Thanks again for all the help.
> Regards,
> Sarvesh
Hello Sarvesh,
good to hear that you managed to get started. Sorry that I assumed that
you are a student interested in GSoC participation. We currently have
the phase where the students start to search for projects.
Best regards
Christian
> On Wed, Mar 6, 2019 at 10:18 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Am 06.03.19 um 21:17 schrieb Sarvesh Patkar:
>     > Thank you for the responses!
>     > Chris,
>     > I was using Ben's repository and not git.rtems.org
>     <http://git.rtems.org>
>     > <http://git.rtems.org>. I will test it with
>     > https://git.rtems.org/rtems-source-builder/ some time later today
>     to see
>     > if it works.
>     > Christian,
>     > I didn't know the documentation is outdated.
>     Like I said: I have to update it some when.
>     > I would like to understand what part of Beaglebone black BSP has not
>     > been implemented. The list on the ticket mentioned
>     > PRU - programmable realtime units, interesting realtime applications
>     > I2C
>     > ADC
>     > Framebuffer
>     > USB
>     > Ethernet
>     > GPIO
>     > CAN
>     > MMC (internal flash & sdcard)
>     From the list on the bottom of the ticket, the following are still open:
>         ADC
>         Framebuffer
>         GPIO
>         CAN
>         USB OTG (like CDC ethernet or CDC mass storage - not sure about the
>     original beagle board but would be great on the beagle bone black)
>     Note that already at least one other student is planning a BBB project.
>     Of course you can apply to the same. But be aware that we won't have two
>     projects with the same target. If you are working on different parts of
>     BBB, that's OK.
>     What I told the other student:
>     - The Framebuffer could be a decent package. (He asked about that on the
>     mailing list already.)
>     - I have no idea what to do with the PRUs. So if you are interested in
>     them, try to bring some ideas.
>     - All other packages are most likely quite small. But a combination of
>     these could be a package too.
>     - If you want to add some other Beagle variant, we would have to have a
>     look at how much work to expect and if it is enough for a project.
>     > From the repository
>     https://git.rtems.org/rtems/tree/bsps/arm/beagle, it
>     > seems the i2c, spi, uart, gpio, pwm are implemented. I am not sure
>     if I
>     > am looking at the right place. So, it would be great if you could
>     let me
>     > know, where to look, to understand the BSP better.
>     > I understand why we don't need the tools to build the application. I
>     > will try your way with the scripts from the Gitlab repository and
>     try to
>     > build a sample application.
>     You don't have to use the scripts. But of course you can. Basically the
>     scripts just call RSB and the commands for building RTEMS and libbsd,
>     build the same tools that originally have been build by Bens RSB branch,
>     build a U-Boot and generate a SD-Card image that works without a U-Boot
>     on the board too. So much more than the minimum requirement.
>     > You mentioned a Wifi example, but there is an ethernet chip on
>     board and
>     > no Wifi chip. Is there a reason why an external Wifi chip is used and
>     > not the ethernet chip? Also, are all networking applications for RTEMS
>     > going to use the rtems-libbsd going forward?
>     Some parts of WiFi have been a GSoC project that I mentored in 2017.
>     Therefore I needed a test platform. The student back then added (benath
>     some other stuff) wpa_supplicant and a driver for a RTL8188 based stick.
>     The WiFi sample has grown to a more universal one. Since Christmas it
>     includes Ethernet too.
>     Best regards
>     Christian
>     > Thank you for the help.
>     > Regards,
>     > Sarvesh
>     > On Wed, Mar 6, 2019 at 8:52 AM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     Am 06.03.19 um 12:11 schrieb Chris Johns:
>     >     > On 6/3/19 6:07 pm, Sarvesh Patkar wrote:
>     >     >> Hey everyone,
>     >     >> I went through the quick start guide and could build the Hello
>     >     World for the
>     >     >> sparc/erc32 target.
>     >     >> I would like to contribute to RTEMS in adding functionality and
>     >     maybe, writing
>     >     >> BSPs for some development boards that I have. I started with
>     >     Beaglebone Black.
>     >     > Welcome and this sounds great.
>     >     Note that the Beagle Bone Black is already quite well
>     supported (except
>     >     for the outdated documentation). Of course there is always room to
>     >     improvement.
>     >     >> There are a few questions that I have as follows.
>     >     >>  1. There is a build set called beagle.bset that is defined in
>     >     Ben Gras's Github
>     >     >>     repository
>     >     (https://github.com/bengras/rtems-source-builder/tree/beagle),
>     >     >>     that hasn't been merged into the main rtems-source-builder
>     >     git repository.
>     >     >>     Is there a way to know if that will happen?
>     >     > It could be if it is updated so it can be merged to master.
>     >     The build set compiles some additional tools and libraries.
>     The tools
>     >     are useful but not necessary to create bootable images. Most
>     likely Ben
>     >     used the libraries for some project.
>     >     Please note that I write the following without detailed tests
>     from some
>     >     notes / scripts. So there might could be typos or some
>     problems with the
>     >     order.
>     >     For a BBB with an up to date U-Boot (newer than about 2017) on
>     your
>     >     Beagle you don't have to use these tools. The U-Boot that is
>     provided by
>     >     the official BBB images now looks for a uEnv.txt on your SD
>     and executes
>     >     that if it is available.
>     >     You can build the toolchain and system the normal way like any
>     other
>     >     RTEMS tool chain (like you did for erc32) from master. Beneath
>     that you
>     >     need a mkimage from U-Boot. Any recent version should do. As
>     soon as you
>     >     have your executable you need the following steps:
>     >     arm-rtems5-objcopy app.exe -O binary app.bin
>     >     gzip -9 app.bin
>     >     mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000
>     -n RTEMS
>     >     -d app.bin.gz rtems-app.img
>     >     You can then copy the rtems-app.img to the root directory of a
>     >     FAT-formatted SD card. Put a uEnv.txt with the following
>     content beneath
>     >     it (the line with boot=... and the following are one - my mail
>     client
>     >     just breaks it):
>     >     setenv bootdelay 5
>     >     uenvcmd=run boot
>     >     boot=fatload mmc 0 0x80800000 rtems-app.img ; fatload mmc 0
>     0x88000000
>     >     am335x-boneblack.dtb ; bootm 0x80800000 - 0x88000000
>     >     The last file that you need is a device tree file
>     >     (am335x-boneblack.dtb). The simplest way to get that is to
>     copy it from
>     >     a Linux or FreeBSD image for the BBB. Copy it together with
>     the other
>     >     files to the root of the disk.
>     >     A disk that is prepared in that way should boot the RTEMS
>     application if
>     >     you put it in your BBB.
>     >     Like I said: I mostly wrote that down from head / scripts. I
>     should
>     >     update the README of the Beagle BSP sometimes but I haven't
>     managed to
>     >     bring myself to do it yet.
>     >     In the last two years, I have used some hacked together
>     scripts to build
>     >     a development environment that I used to test GSoC code.
>     Basically it
>     >     builds the same tools that Bens repo would build. It isn't
>     integrated as
>     >     nicely into RSB but it worked for me. The repo isn't totally
>     up to date
>     >     (last updated to RTEMS master on last Chrismas) but it should
>     still
>     >     work. If it helps you, you can find the scripts here:
>     >         https://gitlab.com/c-mauderer/rtems-bbb
>     >     There is also a WiFi-Sample application in the repo that uses
>     quite a
>     >     lot of the hardware.
>     >     Best regards
>     >     Christian
>     >     >>  2. The instructions given in the blog link mentioned on the
>     >     >>     ticket https://devel.rtems.org/ticket/2891 do not seem to
>     >     work because the
>     >     >>     link for fetching the mpc library is broken/wrong. (I
>     >     corrected the link
>     >     >>     locally and the sb-set-builder seems to go beyond that
>     error)
>     >     I think this
>     >     >>     change was made already in all branches in the official
>     >     repository but not
>     >     >>     Ben's. I see another error while running sb-set-builder
>     >     during compilation
>     >     >>     of ubsan.c (gcc-6.3.0) as follows. Is there a patch for
>     this
>     >     that I can
>     >     >>     apply to fix my local clone of the rsb ?
>     >     > Are you using the master version of the RSB from
>     git.rtems.org <http://git.rtems.org>
>     >     <http://git.rtems.org>?
>     >     > Chris
>     >     >> ../../gcc-6.3.0/gcc/ubsan.c: In function 'bool
>     >     ubsan_use_new_style_p(location_t)':
>     >     >> ../../gcc-6.3.0/gcc/ubsan.c:1474:23: error: ISO C++ forbids
>     >     comparison between
>     >     >> pointer and integer [-fpermissive]
>     >     >>        || xloc.file == '\0' || xloc.file[0] == '\xff'
>     >     >> Any help in this matter is highly appreciated. If not the
>     >     Beaglebone black, I
>     >     >> have some ARM Cortex-M boards that I would like to work
>     towards.
>     >     >> Thank you for the help.
>     >     >> Regards,
>     >     >> Sarvesh
>     >     >> _______________________________________________
>     >     >> users mailing list
>     >     >> users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>
>     >     >> http://lists.rtems.org/mailman/listinfo/users
>     > users mailing list
>     embedded brains GmbH
>     Herr Christian Mauderer
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     Phone: +49-89-18 94 741 - 18
>     Fax:   +49-89-18 94 741 - 08
>     PGP: Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
