Can't run ticker sample on beatnik with the actual rtems-5 master
Mon Mar 11 15:53:36 UTC 2019
On Thu, Feb 28, 2019 at 3:53 AM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> With the actual rtems-master I can not load anymore programs on beatnik
> board (MVME6100)
> [junkes at h rtems-source-builder (master)]$ ls rtems/sources/
> autoconf-2.69.tar.gz
> automake-1.12.6.tar.gz
> binutils-2.32.tar.bz2
> expat-2.1.0.tar.gz
> gcc-7.4.0.tar.xz
> gdb-8.2.1.tar.xz
> gmp-6.1.0.tar.bz2
> isl-0.16.1.tar.bz2
> mpc-1.0.3.tar.gz
> mpfr-3.1.4.tar.bz2
> newlib-1d35a003f.tar.gz
> rtems-tools-551ce0825375a43bd4438713d7a49633eef922b5.tar.bz2
> Boot code created with
> powerpc-rtems5-objcopy -Obinary ticker.exe ticker.boot
> -rwxr-xr-x  1 junkes  staff  219504 Feb 28 09:35 ticker.boot
> On the MVME6100 :
> MVME6100> tftpGet -c141.14.128.53 -s141.14.133.59 -m255.255.240.0
> -a04000000 -fticker.boot
> Network Loading from: /dev/enet0
> Loading File: ticker.boot
> Load Address: 04000000
> Download Buffer Size = User Defined
> Client IP Address      = 141.14.128.53
> Server IP Address      = 141.14.133.59
> Gateway IP Address     = 141.14.128.253
> Subnet IP Address Mask = 255.255.240.0
> Network File Load in Progress...
> Bytes Received =&219504, Bytes Loaded =&219504
> Bytes/Second   =&219504, Elapsed Time =1 Second(s)
> MVME6100> netShut
> /dev/-----------------------------------------
> config addr is 0xf1000cf8
> config data is 0xf1000cfc
> Welcome to RTEMS rtems-5.0.0 (PowerPC/Generic (classic FPU)/beatnik)
> CPU: MPC7457
> Board Type: MVME6100-0163 (S/N E173D29)
> Bus Clock Freq:   133333333 Hz
> CPU Clock Freq:  1266666654 Hz
> Memory:           536870912 bytes
> Now BSP_mem_size = 0x1fe00000
> Configuration.work_space_size = 104d0
> Page table setup finished; will activate it NOW…
> Here the board stucks … no more output ...
> Hi Heinz,
Is this still a problem?
Gedare
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190311/c2776615/attachment.html>
