Can't make testsuites/samples with x86_64-rtems5
Mon Mar 18 08:23:29 UTC 2019
On 18/03/2019 08:55, Heinz Junkes wrote:
> ../../rtems/configure --enable-maintainer-mode --prefix=$HOME/.rtems --target=x86_64-rtems5 --enable-rtemsbsp="amd64" --enable-posix --enable-cxx --enable-networking
> make all
> Making all-am in amd64
> make[6]: Entering directory `/home/travis/RTEMS_DEV/build/b-x86_64/x86_64-rtems5/c/amd64/lib/libbsp/x86_64/amd64'
> make[6]: Nothing to be done for `all-am'.
> make[6]: Leaving directory `/home/travis/RTEMS_DEV/build/b-x86_64/x86_64-rtems5/c/amd64/lib/libbsp/x86_64/amd64'
> make[5]: Leaving directory `/home/travis/RTEMS_DEV/build/b-x86_64/x86_64-rtems5/c/amd64/lib/libbsp/x86_64'
> make[4]: Leaving directory `/home/travis/RTEMS_DEV/build/b-x86_64/x86_64-rtems5/c/amd64/lib/libbsp'
> Making all-am in testsuites
> make[4]: Entering directory `/home/travis/RTEMS_DEV/build/b-x86_64/x86_64-rtems5/c/amd64/testsuites'
> Making all-am in samples
> make[5]: Entering directory `/home/travis/RTEMS_DEV/build/b-x86_64/x86_64-rtems5/c/amd64/testsuites/samples'
> x86_64-rtems5-gcc  -mno-red-zone -mcmodel=large -Werror=return-type -O2 -g -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -B./../../lib/libbsp/x86_64/amd64 -B/home/travis/RTEMS_DEV/rtems/bsps/x86_64/amd64/start -specs bsp_specs -qrtems -L./../../cpukit -L/home/travis/RTEMS_DEV/rtems/bsps/x86_64/shared/start -Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar -Wl,--gc-sections -o base_sp.exe base_sp/base_sp-init.o base_sp/base_sp-apptask.o ./../../lib/libbsp/x86_64/amd64/librtemsbsp.a ./../../cpukit/librtemscpu.a
> /home/travis/.rtems/lib/gcc/x86_64-rtems5/7.4.0/../../../../x86_64-rtems5/bin/ld: cannot find crti.o: No such file or directory
> collect2: error: ld returned 1 exit status
> make[5]: *** [base_sp.exe] Error 1
> make[5]: Leaving directory `/home/travis/RTEMS_DEV/build/b-x86_64/x86_64-rtems5/c/amd64/testsuites/samples'
> make[4]: *** [samples] Error 2
Sorry, this problem was fixed only recently (last week). You have to
rebuild the tools using the latest RSB. This BSP is work in progress:
https://docs.rtems.org/branches/master/user/bsps/bsps-x86_64.html#amd64
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
