Waf's dependency on Python3
Adam Lindberg adam.lindberg at stritzinger.com
Wed Mar 20 13:12:09 UTC 2019
I assume you mean rtems-libbsd/waf_libbsd.py? Can’t figure out how to run that:
    + python3 /opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-libbsd/waf_libbsd.py configure --prefix=/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-install/rtems/5/ --rtems-bsps=arm/atsamv --buildset=/opt/grisp/grisp-software/cd73e8f90d/build/libbsd-buildset.ini
    Traceback (most recent call last):
    File "/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-libbsd/waf_libbsd.py", line 49, in <module>
        import rtems_waf.rtems as rtems
    File "/opt/grisp/grisp-software/cd73e8f90d/rtems-libbsd/rtems_waf/rtems.py", line 848, in <module>
        from waflib import Task
    ModuleNotFoundError: No module named ‘waflib'
Cheers,
Adam
Adam Lindberg
Senior Developer
+49 8135 69492 90
Peer Stritzinger GmbH    Geschäftsführer: Peer Stritzinger
Aumüllerstr. 14          Handelsregister München HRB 133238
82216 Maisach            www.stritzinger.com
> On 20. Mar 2019, at 14:07, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 20/03/2019 14:00, Adam Lindberg wrote:
>> I’m having less luck using Python 3 on macOS 10.14 (via Hombrew):
>>     + python3/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-install/rtems/5//bin/waf configure --prefix=/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-install/rtems/5/ --rtems-bsps=arm/atsamv --buildset=/opt/grisp/grisp-software/cd73e8f90d/build/libbsd-buildset.ini
> Does it work with the waf which ships with rtems-libbsd?
