Waf's dependency on Python3
Wed Mar 20 13:16:14 UTC 2019
On 20/03/2019 14:12, Adam Lindberg wrote:
> I assume you mean rtems-libbsd/waf_libbsd.py? Can’t figure out how to run that:
>      + python3 /opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-libbsd/waf_libbsd.py configure --prefix=/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-install/rtems/5/ --rtems-bsps=arm/atsamv --buildset=/opt/grisp/grisp-software/cd73e8f90d/build/libbsd-buildset.ini
>      Traceback (most recent call last):
>      File "/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-libbsd/waf_libbsd.py", line 49, in <module>
>          import rtems_waf.rtems as rtems
>      File "/opt/grisp/grisp-software/cd73e8f90d/rtems-libbsd/rtems_waf/rtems.py", line 848, in <module>
>          from waflib import Task
>      ModuleNotFoundError: No module named ‘waflib'
I seems you use an older libbsd. In Oktober 2018 we added the waf script
to libbsd:
https://git.rtems.org/rtems-libbsd/log/waf
We should find and fix the issues in the current libbsd.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
