Waf's dependency on Python3
Adam Lindberg adam.lindberg at stritzinger.com
Thu Mar 21 09:49:53 UTC 2019
Thats sounds like a good suggestion. How would I go about updating rtems-libbsd? Just point the latest master or is there a tag we should use?
Cheers,
Adam
Adam Lindberg
Senior Developer
+49 8135 69492 90
Peer Stritzinger GmbH    Geschäftsführer: Peer Stritzinger
Aumüllerstr. 14          Handelsregister München HRB 133238
82216 Maisach            www.stritzinger.com
> On 20. Mar 2019, at 14:16, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 20/03/2019 14:12, Adam Lindberg wrote:
>> I assume you mean rtems-libbsd/waf_libbsd.py? Can’t figure out how to run that:
>>     + python3 /opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-libbsd/waf_libbsd.py configure --prefix=/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-install/rtems/5/ --rtems-bsps=arm/atsamv --buildset=/opt/grisp/grisp-software/cd73e8f90d/build/libbsd-buildset.ini
>>     Traceback (most recent call last):
>>     File "/opt/grisp/grisp-software/cd73e8f90d/build/..//rtems-libbsd/waf_libbsd.py", line 49, in <module>
>>         import rtems_waf.rtems as rtems
>>     File "/opt/grisp/grisp-software/cd73e8f90d/rtems-libbsd/rtems_waf/rtems.py", line 848, in <module>
>>         from waflib import Task
>>     ModuleNotFoundError: No module named ‘waflib'
> I seems you use an older libbsd. In Oktober 2018 we added the waf script to libbsd:
> https://git.rtems.org/rtems-libbsd/log/waf
> We should find and fix the issues in the current libbsd.
