Sqlite building failure using rtems-source-builder
    JunBeom Kim
    jbkim at e-coretech.kr
    Tue Mar 26 07:58:13 UTC 2019
Dear Sir,
I am tring to build Sqlite 3 using rtems-source-builder for ARM
target(Realview-A9).
I already installed rtems-package in
"~/projects/rtems-5.0/target/rva9-libbsd-19q1/rtems-package".
Also, rtems toolchain is installed "/opt/rtems5.0-arm-19q1". My host machine
is Ubuntu 16.04.
My first trial is below according to source-builder.txt
../source-builder/sb-set-builder --log=log_sqlite.txt
--prefix=~/projects/rtems-5.0/target/rva9-libbsd-19q1/rtems-package
--with-tools=/opt/rtems5.0-arm-19q1 --with-rtems-bsp=realview_pbx_a9_qemu
--host=arm-rtems5.0 databases/sqlite
But, error message is in below;
RTEMS Source Builder - Set Builder, 5.not_released
Build Set: databases/sqlite
config: databases/sqlite-3.8.8.1-1.cfg
error: config error: rtems-bsp.cfg:27: No RTEMS target specified:
--rtems-bsp=arch/bsp (or --target=target)
Build FAILED
Build Set: Time 0:00:00.005160
Build FAILED
My second trial is below;
--with-tools=/opt/rtems5.0-arm-19q1 --target=realview_pbx_a9_qemu
error: config error: rtems-bsp.cfg:31: Canadian cross building for BSP is
not supported.
Build FAILED
Build Set: Time 0:00:00.003632
Build FAILED
If you are successful for building sqlite, please let me know that.
Best Regards,
JunBeom Kim
President / EmbedCoreTech
Phone: +82-31-396-5584
Fax: +82-504-065-5720
Mobile:+82-10-6425-5720
Email:  <mailto:jbkim at e-coretech.kr> jbkim at e-coretech.kr
Web:  <http://www.e-coretech.kr> www.e-coretech.kr
URL: <http://lists.rtems.org/pipermail/users/attachments/20190326/fb050497/attachment.html>
