Application build in Eclipse gives error
Thu Mar 28 09:50:17 UTC 2019
On 28/03/2019 09:49, Amarnath MB wrote:
> My development platform is MingW64 on Windows 10.
> The strange part is that when I build my BSP from MingW shell then
> this error is not reported and everything gets built successfully.
> Once I install my bsp and use it in eclipse to build application it
> gives the above error.
> After some googling, I came to know that this is some issue related to
> the Linker standard path.
The GCC cannot find its internal target libraries. I guess you don't
call GCC in a MSYS shell in eclipse so the behaviour is different. You
can print out the compiler search paths with "gcc -E -P -v -dD
empty-file.c".
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
