Memory allocation speed is slow by memory fragmentation on long-run test.
JunBeom Kim jbkim at e-coretech.kr
Fri Mar 29 07:47:43 UTC 2019
Dear Sebastian,
There is not any problem using my patch code in my customer side until now.
I will consider TLSF.
Thank you very much for TLSF information.
On referencing, I will investigate libbsd's SD-Card speed improvement for
IMX target(your side: i.MX7D, my side: i.MX6Q) soon.
If there is internal progress, I will share patch code for you.
Best Regards,
JunBeom
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Friday, March 29, 2019 4:39 PM
To: JunBeom Kim <jbkim at e-coretech.kr>; users at rtems.org
Subject: Re: Memory allocation speed is slow by memory fragmentation on
long-run test.
On 29/03/2019 08:19, JunBeom Kim wrote:
> Dear Sir,
> I am still working with my customer using RTEMS based Qt Framework in
> long time.
> My customer are using memory allocation(malloc, realloc, free) with
> frequency about small size(64, 128, 256, 512, 1024 byte, etc).
> When RTEMS application is run in long time(for example: 6 hours),
> malloc() or realloc() speed is slower due to memory fragmentation.
> When I used other RTOS(eg: Nucleus, uC/OS, iTRON, etc) before, there
> was almost same issue.
A first-fit allocator (which is used by RTEMS) is completely useless for
dynamic memory workloads. It is all right if you only allocate and never
free.
> I used partition memory management for resolving this.
> Is it correct method ?
We used TLSF in such situations:
https://github.com/mattconte/tlsf
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
