Sqlite building failure using rtems-source-builder
Jonathan Brandmeyer jbrandmeyer at planetiq.com
Fri Mar 29 18:49:57 UTC 2019
On Fri, Mar 29, 2019 at 12:57 AM JunBeom Kim <jbkim at e-coretech.kr> wrote:
> Because there is file locking problem due to fcntl(F_SETLK) unsupported feature, DB file access is error.
SQLite3 ships with a set of VFS methods that avoid file locking
entirely, named "unix-none".  There are several methods available to
pick this style of locking.  Since my application is being tested on
both a general-purpose POSIX OS as well as RTEMS, I change the VFS
type in my RTEMS startup code using sqlite3_vfs_find() and
sqlite3_vfs_register().  There is also a "unix-dotfile" method
available, and we may switch over to that for better error-handling
paths.
In the case of the "unix-none" locking mode, you must maintain the
invariant that there is exactly one database connection per database
file in the entire application.  That seems OK to me, so we set the
-DSQLITE_DEFAULT_LOCKING_MODE=1 (EXCLUSIVE) to help enforce it in the
testing environment.
> After I modify this, there is not problem using simple sqlite example code(attached: main.c).
> But, there is side-effect(for example: memory leaking issue by locking patch code) in my customer side using RTEMS.
Regarding your memory leak, don't forget to sqlite3_close() the
database.  This must be done even if sqlite3_open() fails.
HTH,
Jonathan Brandmeyer
