Beaglebone help needed
Sarvesh Patkar psarvesh314 at gmail.com
Mon Mar 11 18:52:26 UTC 2019
Hey Gedare,
Can you let me know how the "tag along" mode would work? I think I would
definitely be interested in giving it a try.
Thanks,
Sarvesh
On Mon, Mar 11, 2019 at 9:07 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 7, 2019 at 5:03 AM Christian Mauderer <
> christian.mauderer at embedded-brains.de> wrote:
>> Am 07.03.19 um 09:52 schrieb Sarvesh Patkar:
>> > Hey Chris and Christian,
>> > Thank you for the prompt responses.
>> > I think there is no update needed to the rtems-source-builder at this
>> > time for beaglebone. After understanding what Christian told me, I
>> > realized that I just needed to use the rtems-arm build set. Then, I
>> > followed this
>> > README https://git.rtems.org/rtems/tree/bsps/arm/beagle/README from the
>> > master branch of rtems and ran the ticker sample on the beaglebone.
>> > For now, I think I will stick to figuring out more about the PRU or ADC
>> > peripherals and try to write the respective drivers for the BSP.  Since
>> > I am not associated with GSoC or any other institute, I will keep an eye
>> > on the mailing lists and make sure I am not duplicating work which
>> > others are doing on the Beaglebone black.
>> > Thanks again for all the help.
>> > Regards,
>> > Sarvesh
>> Hello Sarvesh,
>> good to hear that you managed to get started. Sorry that I assumed that
>> you are a student interested in GSoC participation. We currently have
>> the phase where the students start to search for projects.
> I had some similar thoughts in my head as I was reading. Sarvesh, if
> you're interested, you might be able to co-mentor a BB-related project in
> "tag along" mode just to keep yourself involved and learning. Let me know
> if that is something you'd like to try.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190311/d58a7d33/attachment-0002.html>
