task info
Mathew Benson mbenson at windhoverlabs.com
Fri Mar 22 00:27:10 UTC 2019
Not easily.  That's good to know though.  Thanks.
On Thu, Mar 21, 2019 at 7:23 PM Ian Caddy <ianc at goanna.iinet.net.au> wrote:
> Hi Matthew,
> Do you have access to the shell on a serial or telnet console?
> The RTEMS shell has a "task" command that shows the state of all the tasks
> running in your system:
> MNTB [/] # task
> ID       NAME                 SHED PRI STATE  MODES    EVENTS WAITINFO
> 0a010001 USBd                 UPD  200 TIME   P:T:nA   NONE
> 0a010003 ERRM                 UPD   55 MSG    P:T:nA   NONE   22010003
> 0a010004 ADLT                 UPD   92 MSG    P:T:nA   NONE   22010006
> Based on the wait info, you can work out what it is waiting on using the
> other shell commands, such as:
> queue or sema
> MNTB [/] # queue
>   ID       NAME   ATTRIBUTES   PEND   MAXPEND  MAXSIZE
> 22010001   USBr    DEFAULT        0    3000        1
> 22010002   USBt    DEFAULT       40    10000       1
> 22010003   EMIQ    PR             0      15       32
> In the example above, the task ERRM is waiting for a message on the queue
> EMIQ.
> If you do not have access to the shell, you can try to follow through what
> the shell actually does in the code, and hopefully it will provide the
> information that you are looking for.
> regards,
> Ian Caddy
> On 22/03/2019 3:41 am, Mathew Benson wrote:
> What's the best way to determine the status of a task?  Is there an API to
> determine if its pending or a runnable state?  Is there an API to determine
> what its pending on?  I'm trying to determine what some tasks stopped
> executing and I can't use a debugger.  Preferably, can somebody point me to
> a symbol that I can peek?
> *Mathew Benson*
> CEO | Chief Engineer
> Windhover Labs, LLC
> 832-640-4018
> www.windhoverlabs.com
> users mailing listusers at rtems.orghttp://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
*Mathew Benson*
Windhover Labs, LLC
832-640-4018
URL: <http://lists.rtems.org/pipermail/users/attachments/20190321/dd8c8ffb/attachment-0002.html>
