Sqlite building failure using rtems-source-builder
Joel Sherrill
joel at rtems.org
Tue Mar 26 22:06:32 UTC 2019
I think the problem is in this command.
../source-builder/sb-set-builder --log=log_sqlite.txt
--prefix=~/projects/rtems-5.0/target/rva9-libbsd-19q1/rtems-package
--with-tools=/opt/rtems5.0-arm-19q1 --target=realview_pbx_a9_qemu
--host=arm-rtems5.0 databases/sqlite
From
https://docs.rtems.org/branches/master/user/rsb/third-party-packages.html#
../source-builder/sb-set-builder --log=log_sis_net_snmp \
--prefix=$HOME/development/rtems/bsps/4.11 \
--with-tools=$HOME/development/rtems/4.11 \
--host=sparc-rtems4.11 --with-rtems-bsp=erc32 4.11/net-mgmt/net-snmp
By specifying host and target, it looks like you are doing a Canadian
cross.
Hopefully Chris can pop up and verify the command. Offhand, I am not sure
if the command in the documentation is correct.
--joel
On Tue, Mar 26, 2019 at 9:25 AM Jonathan Brandmeyer <
jbrandmeyer at planetiq.com> wrote:
> My team hasn't gotten to the stage of actually using SQLite in the
> RTEMS environment yet, but it builds just fine. We don't use
> rtems-source-builder to do it. We are just using the latest stable
> amalgamation release, supplied by sqlite.org. We build it with the
> same options that the configure script normally uses to build a .so on
> Linux, except that we also specify -DSQLITE_OMIT_LOAD_EXTENSION. I've
> seen some documentation to the effect that rtems actually does support
> dlopen/dlsym, but we haven't tried it and we don't need it for our
> mission.
> If I understand correctly, the only conflicts with RTEMS should be
> SQLIte's dependency on mmap. RTEMS does not provide virtual memory at
> all, so mmap and kin are only stub functions that return an error.
> The SQLite3 documentation does describe how to configure the
> write-ahead log (WAL) in such a way that it should not rely on mmap at
> runtime, though.
> Hope that helps,
> Jonathan Brandmeyer
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190326/ea6252c4/attachment-0002.html>
